Problem with idle-timeout
Hi.
We have a problem with an idle-timeout witch a 3640 (ios release 12.2(40).
It seems that idle-timeout timer is non cleared, so when it reach configured timeout it bring down call.
Configuration of int dialer is:
int dialer100
ip address negotiated
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer idle-timeout 600
dialer string *********
dialer-group 2
no fair-queue
no cdp enable
ppp authentication chap
ppp chap hostname ********
ppp chap password ********
and here:
cisco3640#sh isd active
ISDN ACTIVE CALLS
Call Calling Called Remote Seconds Seconds Seconds Charges
Type Number Number Name Used Left Idle Units/Currency
Out ---N/A--- 0654224972 ARCNED 401 3198 401 0
seconds idle are 401, but at this time we are transmitting data across dialer100 interface
if I issue a ping command inside the router, idle seconds are properly cleared, but from the other machine this wouldn't happen.
Anyone have an idea about this problem?
Thanks in advance
Daniele
1 REPLY
Hall of Fame Super Silver
Re: Problem with idle-timeout
Daniele
I am not sure that I fully understand what is happening in your situation. It would help to have the config from both routers. And it would help to inlude the dialer-list from the config that goes with the dialer group from the dialer interface.
In general what we frequently see in situations similar to what you describe is that one of the routers does not have dialer group configured or that the dialer-list is very restrictive. If we could see these details from your routers we could make a better determination. But I believe that your description that if you ping on this router the idle seconds are cleared but not on the other router is an indication that the other router does not have dialer group configured.
Rick
128
