Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Problem with nm-30dm
I have a Cisco 3845 router and a nm-2ce21t1-pri and a nm-30dm and I use E1 CAS but when I dial with analoge modem it seems nm-30dm doesen't work and the line is busy, when I use "show controller e1" both lines are up. and i know that both E1s are work, because i tested them with Cisco 5350.
1 REPLY
Re: Problem with nm-30dm
Cisco AS5350 Universal gateway is supporting 2/4/8-Port T1/7pPort E1 configuration. But Cisco-3845 have only one Auxiliary Port ,which will support up to 115.2 Kbps.so you face problem.
132
