Problem with Reverse telnet on 2611 (NM-32A)
I have been trying to get 2611 to work as a Terminal server to be able to reverse telnet to couple of routers. But I can't get it to work on the NM module, however it is working through the AUX port.
This is the config of the router:
Current configuration : 725 bytes
version 12.2
service config
service timestamps debug uptime
service timestamps log uptime
hostname R1
enable secret xxx
ip subnet-zero
interface Loopback1
ip address 172.16.1.1 255.255.255.255
interface Ethernet0/0
ip address 192.168.100.90 255.255.255.0
half-duplex
interface Ethernet0/1
no ip address
half-duplex
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.100.1
ip http server
line con 0
line 33 64
session-timeout 30
exec-timeout 0 0
password c
login
no exec
transport input all
line aux 0
session-timeout 30
exec-timeout 0 0
password c
login
no exec
transport input all
line vty 0 4
password c
login
end
Bronze
Re: Problem with Reverse telnet on 2611 (NM-32A)
is this the entire configuration ? Have a look at this sample configuration:
boot-start-marker
boot-end-marker
enable secret 5 XXXXXXXXXXXXXXXXXXXXXXX
username root privilege 15 password 7 XXXXXXXXXXXXXXXXXXXXXX
no aaa new-model
ip subnet-zero
no ip domain lookup
ip host Router1 2001 172.16.1.1
ip host Router2 2002 172.16.1.1
ip host Router3 2003 172.16.1.1
ip host Router4 2004 172.16.1.1
ip host Router5 2005 172.16.1.1
ip host Router6 2006 172.16.1.1
ip host Router7 2007 172.16.1.1
ip host Router8 2008 172.16.1.1
ip host Router9 2009 172.16.1.1
ip host Router10 2010 172.16.1.1
ip host Router11 2011 172.16.1.1
ip host Router12 2012 172.16.1.1
ip host Router13 2013 172.16.1.1
ip host Router14 2014 172.16.1.1
ip host Router15 2015 172.16.1.1
ip host Router16 2016 172.16.1.1
interface Loopback1
half-duplex
no ip address
half-duplex
ip classless
ip http server
line con 0
line 1
session-timeout 30
exec-timeout 0 0
no exec
transport input telnet
line 2
session-timeout 30
exec-timeout 0 0
no exec
line 3
session-timeout 30
exec-timeout 0 0
no exec
line 4
session-timeout 30
exec-timeout 0 0
no exec
line 5
session-timeout 30
exec-timeout 0 0
no exec
line 6
session-timeout 30
exec-timeout 0 0
no exec
line 7
session-timeout 30
exec-timeout 0 0
no exec
line 8
session-timeout 30
exec-timeout 0 0
no exec
line 9
session-timeout 30
exec-timeout 0 0
no exec
line 10
session-timeout 30
exec-timeout 0 0
no exec
line 11
session-timeout 30
exec-timeout 0 0
no exec
speed 38400
line 12
session-timeout 30
exec-timeout 0 0
no exec
line 13
session-timeout 30
exec-timeout 0 0
no exec
line 14
session-timeout 30
exec-timeout 0 0
no exec
line 15
session-timeout 30
exec-timeout 0 0
no exec
line 16
session-timeout 30
exec-timeout 0 0
no exec
line aux 0
line vty 0 4
exec-timeout 60 0
login local
end
The line numbering depends on the slot in which the module is inserted, Slot 0 has line numbers 0 thru 32, Slot 1 line numbers 33 thru 65, etc...
In the above example, the module is installed in slot 0.
The third section of each command contains the port number for the devices, and the last two digits of the number designate the port. For example, 2001 follows the first router ("Router1"), meaning this router is on port 1. The last part of the command contains the IP address of the Ethernet port on the console server.
By creating these names, you don't need to know which port the device is on. All you need to do is Telnet to the host (in this case, Router1) off of the console server.
You could also reach this device directly from a PC. For example, you could Telnet to 172.16.1.1 2016 from your PC. This tells the Telnet client to go to port 2016 instead of the default Telnet port 23.
HTH,
Nethelper
Hi HTH, thank you for the response.
I have been trying a telnet to the loopback IP address on port 2033, which should be the first unit connected. I have been thinking if it could be wrong cabling on the RJ45 connector. I have these colors: Green, white, blue, orange, brown, yellow, red and black in that order from pin 1 to pin 8.
R.
Haukur
Bronze
Hello Haukur,
the colors do not really matter, as long as you are using a rolled cable, which means that all pins are reversed:
1-8
2-7
3-6
4-5
5-4
6-3
7-2
8-1
What happens when you do the telnet, what message does the system give you ?
Nethelper
Hi Nethelper,
How can I know if it is a rolled cabel or not on the Octal cable?
I'm getting the password prompt and after that it I have a connection but nothing is displaying on the screen.
R.
Haukur
Bronze
Hello Haukur,
have a look at the cable depicted in the link below, if this is what yours looks like, it is a rolled cable. As a matter of fact, if it weren't, you would not even get a password prompt. You have your NM installed in slot 0, right ? Can you post the output of 'show line' ? It could also be that the line is busy, try a 'clear line' .
Nethelper
Hi Nethelper,
I'm getting the password prompt from the Terminal server, I have "login" on the lines. I have tried clearing the line and login in again with no luck. I can't see the link you are mentioning. The NM module is in slot 1 on the 2600. I don't have access to the box right now but I'll post the output of show line later today.
R.
Haukur
Bronze
Hello Haukur,
take the ´login´ command off the lines, and see if that makes a difference...
Nethelper
It doesn't matter. Do you know the colors of the RJ45 connectors on the Octal cable?
R.
Haukur
Bronze
Hello Haukur,
have a look at this link, it describes the octal cable in detail:
Asynchronous Connections
CAB-OCTAL-ASYNC Cable Pinouts
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_tech_note09186a00801c9a10.shtml
Also, have a look at this link, it describes the exact configuration for a terminal server, check if you might have missed something:
Configuring a Terminal/Comm Server
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a008014f8e7.shtml
Nethelper
The problem is solved, it was the cabling of the RJ45 connectors.
1066
