01-14-2006 11:29 AM
I have trouble with my modem dial-in in an other router using his isdn interface.
The problem looks like the following:
The calling router:
router-2523#debug dialer events
Dial on demand events debugging is on
router-2523#ping 172.16.4.1
Sending 5, 100-byte ICMP Echos to 172.16.4.1, timeout is 2 seconds:
00:17:50: Se5 DDR: rotor dialout [best] least recent failure is also most recent failure
00:17:50: Se5 DDR: rotor dialout [best] also has most recent failure
00:17:50: Se5 DDR: Dialing cause ip (s=172.16.4.2, d=172.16.4.1)
00:17:50: Se5 DDR: Attempting to dial 51
00:17:50: CHAT5: Attempting async line dialer script
00:17:50: CHAT5: Dialing using Modem script: Dialout & System script: none
00:17:50: CHAT5: process started
00:17:50: CHAT5: Asserting DTR
00:17:50: CHAT5: Chat script Dialout started.....
Success rate is 0 percent (0/5)
router-2523#
00:18:02: CHAT5: Found abort string BUSY expecting CONNECT
00:18:02: CHAT5: Chat script Dialout finished, status = Connection aborted
00:18:02: Se5 DDR: disconnecting call
router-2523#
The called router:
router-2503-II#debug isdn events
ISDN events debugging is on
router-2503-II#debug isdn q931
ISDN Q931 packets debugging is on
router-2503-II#
00:18:58: ISDN BR0: RX <- SETUP pd = 8 callref = 0x01
00:18:58: Bearer Capability i = 0x9090A3
00:18:58: Channel ID i = 0x8A
00:18:58: Progress Ind i = 0x8583 - Origination address is non-ISDN
00:18:58: Calling Party Number i = 0x01, 0x83, '15', Plan:ISDN, Type:Unknown
00:18:58: Called Party Number i = 0x81, '51', Plan:ISDN, Type:Unknown
00:18:58: CCBRI_Go Fr L3 pkt (Len=27) :
00:18:58: 5 1 81 90 4 3 90 90 A3 18 1 8A 1E 2 85 83 6C 4 1 83 31 35 70 3 81 35 31
00:18:58:
00:18:58: ISDN BR0: Incoming call id = 0x000B, dsl 0
00:18:58: ISDN BR0: LIF_EVENT: ces/callid 1/0xB HOST_INCOMING_CALL
00:18:58: ISDN BR0: HOST_INCOMING_CALL: (non-POTS) VOICE
00:18:58: ISDN BR0: HOST_INCOMING_CALL: (1) call_type = VOICE
00:18:58: ISDN BR0: HOST_INCOMING_CALL: voice_answer_data = FALSE call type is VOICE ALAW
00:18:58: ISDN BR0: Event: Received a VOICE call from 15 on B2 at 64 Kb/s
00:18:58: ISDN BR0: Event: Accepting the call id 0xB
00:18:58: ISDN BR0: INCOMING CALL: VOICE ERROR: Bearer capability not available(0x3A): bchan 1, call id B
00:18:58: ISDN BR0: process_disconnect(): call id 0xB, call type is VOICE, b_idb 0x24F470, ces 1, cause Bearer capability not available(0x3A)
00:18:58: ISDN: get_isdn_service_state(): idb 0x24F470 bchan 3 is_isdn 1 Not a Pri
00:18:58: CCBRI_Go Fr Host InPkgInfo (Len=9) :
00:18:58: 7 0 1 0 B 3 18 1 8A
00:18:58:
00:18:58: CCBRI_Go Fr Host InPkgInfo (Len=13) :
00:18:58: 5 0 1 0 B 3 8 1 BA 8 2 80 BA
00:18:58:
00:18:58: ISDN BR0: TX -> CALL_PROC pd = 8 callref = 0x81
00:18:58: ISDN BR0: TX -> DISCONNECT pd = 8 callref = 0x81
00:18:58: Cause i = 0x80BA - Bearer capability not available
00:18:58: ISDN BR0: RX <- RELEASE pd = 8 callref = 0x01
00:18:58: CCBRI_Go Fr L3 pkt (Len=4) :
00:18:58: 4D 1 81 97
00:18:58:
00:18:58: ISDN BR0: LIF_EVENT: ces/callid 1/0xB HOST_DISCONNECT_ACK
router-2503-II#
00:18:58: ISDN BR0: HOST_DISCONNECT_ACK: call type is VOICE
00:18:58: ISDN BR0: HOST_DISCONNECT_ACK: VOICE ERROR: Bearer capability not available(0x3A): bchan 1, call id B
00:18:58: ISDN BR0: TX -> RELEASE_COMP pd = 8 callref = 0x81
router-2503-II#
Does anyone know whats going wrong and why I could not get a connection th the 2503-II router? When I try the connection from an other router using isdn on both sides the connection works fine...
I added the configuration of both routers in the attachments...
Best Regards
Marcos
01-14-2006 03:41 PM
from the debug output, it looks like the router is thinking that it gets a voice call. Try and add the command ´isdn incoming-voice data´ to the relevant interface on the 2503.
GP
01-15-2006 04:35 AM
I configured the ISDN BRI Intaerface on the Router-2503-II in the following manner:
router-2503-II#sh run int bri 0
Building configuration...
Current configuration : 133 bytes
interface BRI0
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type basic-net3
end
router-2503-II#
after this I tried it again and got the following debug output:
router-2503-II#
00:11:54: ISDN BR0: RX <- SETUP pd = 8 callref = 0x01
00:11:54: Bearer Capability i = 0x9090A3
00:11:54: Channel ID i = 0x8A
00:11:54: Progress Ind i = 0x8583 - Origination address is non-ISDN
00:11:54: Calling Party Number i = 0x01, 0x83, '15', Plan:ISDN, Type:Unknown
00:11:54: Called Party Number i = 0x81, '51', Plan:ISDN, Type:Unknown
00:11:54: CCBRI_Go Fr L3 pkt (Len=27) :
00:11:54: 5 1 81 90 4 3 90 90 A3 18 1 8A 1E 2 85 83 6C 4 1 83 31 35 70 3 81 35 31
00:11:54:
00:11:54: ISDN BR0: Incoming call id = 0x0008, dsl 0
00:11:54: ISDN BR0: LIF_EVENT: ces/callid 1/0x8 HOST_INCOMING_CALL
00:11:54: ISDN BR0: HOST_INCOMING_CALL: (non-POTS) VOICE
00:11:55: ISDN BR0: HOST_INCOMING_CALL: (1) call_type = VOICE
00:11:55: ISDN BR0: HOST_INCOMING_CALL: voice_answer_data = TRUE call type is VOICE ALAW
00:11:55: ISDN BR0: call id 0x8 call treated as DOV
00:11:55: ISDN BR0: Event: Received a DATA call from 15 on B2 at 64 Kb/s
00:11:55: ISDN BR0: Event: Accepting the call id 0x8
00:11:55: ISDN BR0:2: Incoming call rejected, unbindable
00:11:55: ISDN BR0: process_disconnect(): call id 0x8, call type is DATA, b_idb 0x24F470, ces 1, cause Call rejected(0x15)
00:11:55: ISDN: get_isdn_service_state(): idb 0x24F470 bchan 3 is_isdn 1 Not a Pri
router-2503-II#
00:11:55: ISDN BR0: HOST_INCOMING_CALL: DIALER ERROR 1: bchan 1, call id 8
00:11:55: CCBRI_Go Fr Host InPkgInfo (Len=13) :
00:11:55: 5 0 1 0 8 3 8 1 95 8 2 80 95
00:11:55:
00:11:55: ISDN BR0: LIF_EVENT: ces/callid 1/0x8 HOST_DISCONNECT_ACK
00:11:55: ISDN BR0: HOST_DISCONNECT_ACK: call type is VOICE
00:11:55: ISDN BR0: TX -> RELEASE_COMP pd = 8 callref = 0x81
00:11:55: Cause i = 0x8095 - Call rejected
router-2503-II#
Have you any ideas where to look from here?
Marcos
01-15-2006 05:30 AM
Hello Marcos,
try and add the command to your dialer 2 interface as well:
interface Dialer2
ip address 172.16.4.1 255.255.255.0
encapsulation ppp
dialer pool 1
dialer remote-name router-2523
dialer idle-timeout 310
--> isdn incoming-voice data
dialer string 15
dialer-group 1
ppp authentication chap
GP
01-15-2006 10:14 AM
Hi GP,
I found the reason why I can't dial in. I had to add the ppp authenticaton to the bri interface of the router-2503-II and I need to add user router-XXXX on both routers. But now the call lasts only 22 seconds an then it is disconeted.
It seems that no ppp authentication traffic isn't passing the line... I changed the config on router-2523 in the following manner:
line 5
script dialer Dialout
modem InOut
modem autoconfigure type default
transport input all
autoselect during-login
autoselect ppp
stopbits 1
speed 115200
flowcontrol hardware
But it stil doen't work. I enabled more debug options, but I cand finde the error. Do you have any ideas?
I attached the debug outputs.
Thank you.
Marcos
01-16-2006 01:41 PM
01-16-2006 11:04 PM
Hello Marcos,
I think the problem is with your usernames. To summarize:
The router with hostname ´router-2523´ is calling the router with hostname ´router-2503-II. That means that on the router with hostname ´router-2523´, the following username and password need to be configured:
username xxxx password xxxxx
And on the router with hostname ´router-2503-II, the following username and password need to be configured:
Be aware that the CHAP passwords must match on both sides, and that they are case-sensitive...
GP
01-17-2006 06:35 AM
Hi GP,
I configured the usernames and passwords on both sides. It won't work. I also deactivated the CHAP authenticaton and it won't work.
I have some Problems with the PPP LCP negotiation. The Router 2523 don't send any PPP traffic to the router-2503-II. The router-2523 is waiting for any PPP LCP requests. I enbaled the chat script debug and can see that the modem don't get a CONNECT state after dialing the number, but the ISDN line on the router-2503-II comes up/up. This confuses me...
When I try the other direction (the 2503-II router is calling the router 2523) the router-2523 dont receive any PPP trafic and the router-2523 is stil waitng for an answer to his PPP negotiation packets.
I hope this can show the problem more clearly.
Thank you.
Best Regards
Marcos
03-13-2006 09:43 AM
Hi Marcos,
I am experiencing eactly the same symptoms. Did you get it figured out?
I think my problem is that the long distance carrier does not accept my call as digital. As a result the bearer capability gets changed to voice.
http://www.cisco.com/warp/public/793/access_dial/8.html
If you have any further information, please let me know. Does your call involve long distance?
If I get mine resolved, I will post it on the forum on one of my two open postings,
Category: Network Infrasructure: Remote Access: (interesting q931 challenge)
Topic : Interesting q931 challenge
And
Category: Network Infrasructure: WAN Routing and Switching (Long Distance ISDN)
Topic: Long Distance ISDN
Mark
03-13-2006 02:48 PM
Hi Mark,
thank you for your interest. I haven't resolved it. I will keep trying it... I have no long distances, because I use my own local ISDN switch at Home. If you can find some solution to this Problem, please let me know. I'am very interested your solotion...
Marcos
03-16-2006 02:59 PM
The problem seems to be the modem you are using. As we can see from the debugs the 2503 connected on the isdn leg & started PPP while the serial on the 2523 has not even received the connect from the modem hence has no PPP negotiation. Apply following changes to the Change the 2523
chat-script Dialout "" "atdt\T" TIMEOUT 60 CONNECT \c
interface serial5
async default routing
The above change may not fix the problem, but verify the settings on the modem. I am assuming there is a speed or protocol setting that may need to be changed
04-10-2006 11:53 AM
I tried the config above, but it still dosen't work... I figured out that always the serial line 5 remains down/down. Is there some chance to get them to spoofing?
I can see that the serial interface dosen't come up, when the modem tries to connect to the 2503-II router.
I need some command(s) to force the inface to come up when the modem dials out... (???)
Does somebody have an idea? I sit for a long time on this problem and I could'nt get it running...
Marcos
04-10-2006 01:29 PM
I have some aditional info...
I telneted the modem during remote dian-in from the 2503-II router, pick up the call with ATA and I got after 20 seconds the NO CARRIER message.
It looks like the following:
RING
ATA
NO CARRIER
After this I tried to call the 2503-II router:
I received the busy message after 20 seconds:
ATD51
BUSY
Marcos
