04-10-2007 10:26 AM
I have a 2620 being used as a console server. I have an async 32A card in it with two octal cables connected to my deivces. When trying to reverse telnet to any of the lines, all I get is:
% Connection refused by remote host
Here is the configuration:
no network-clock-participate slot 1
no network-clock-participate wic 0
aaa new-model
aaa authentication password-prompt Local_Password:
aaa authentication username-prompt Local_Username:
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa accounting update newinfo
aaa accounting exec default stop-only group tacacs+
aaa accounting commands 15 default stop-only group tacacs+
aaa session-id common
ip subnet-zero
ip cef
interface FastEthernet0/0
ip address 10.20.1.6 255.255.255.0
duplex auto
speed auto
interface Async1
no ip address
async default routing
async mode interactive
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 10.20.1.1
line con 0
line 1
modem InOut
transport input all
stopbits 1
speed 115200
flowcontrol hardware
line 33 64
no exec
transport input telnet
stopbits 1
line aux 0
line vty 0 4
exec-timeout 0 0
04-10-2007 10:26 AM
Here is the output of show line:
DDRTS1001# sh line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
0 CTY - - - - - 0 0 0/0 -
I 1 TTY 115200/115200- inout - - - 0 0 0/0 -
33 TTY 9600/9600 - - - - - 0 0 0/0 -
34 TTY 9600/9600 - - - - - 0 0 0/0 -
35 TTY 9600/9600 - - - - - 0 0 0/0 -
36 TTY 9600/9600 - - - - - 0 1 0/0 -
37 TTY 9600/9600 - - - - - 0 0 0/0 -
38 TTY 9600/9600 - - - - - 0 1 0/0 -
39 TTY 9600/9600 - - - - - 0 0 0/0 -
40 TTY 9600/9600 - - - - - 0 0 0/0 -
41 TTY 9600/9600 - - - - - 0 3 1/0 -
42 TTY 9600/9600 - - - - - 0 3 1/0 -
43 TTY 9600/9600 - - - - - 0 0 0/0 -
44 TTY 9600/9600 - - - - - 0 3 0/0 -
45 TTY 9600/9600 - - - - - 0 0 0/0 -
46 TTY 9600/9600 - - - - - 0 0 0/0 -
47 TTY 9600/9600 - - - - - 0 0 0/0 -
48 TTY 9600/9600 - - - - - 0 0 0/0 -
49 TTY 9600/9600 - - - - - 0 0 0/0 -
50 TTY 9600/9600 - - - - - 0 0 0/0 -
51 TTY 9600/9600 - - - - - 0 0 0/0 -
52 TTY 9600/9600 - - - - - 0 0 0/0 -
53 TTY 9600/9600 - - - - - 0 0 0/0 -
54 TTY 9600/9600 - - - - - 0 0 0/0 -
55 TTY 9600/9600 - - - - - 0 0 0/0 -
56 TTY 9600/9600 - - - - - 0 0 0/0 -
57 TTY 9600/9600 - - - - - 0 0 0/0 -
58 TTY 9600/9600 - - - - - 0 0 0/0 -
59 TTY 9600/9600 - - - - - 0 0 0/0 -
60 TTY 9600/9600 - - - - - 0 0 0/0 -
61 TTY 9600/9600 - - - - - 0 0 0/0 -
62 TTY 9600/9600 - - - - - 0 0 0/0 -
63 TTY 9600/9600 - - - - - 0 0 0/0 -
64 TTY 9600/9600 - - - - - 0 0 0/0 -
65 AUX 9600/9600 - - - - - 0 0 0/0 -
* 66 VTY - - - - - 3 0 0/0 -
67 VTY - - - - - 2 0 0/0 -
68 VTY - - - - - 0 0 0/0 -
69 VTY - - - - - 0 0 0/0 -
70 VTY - - - - - 0 0 0/0 -
Line(s) not in async mode -or- with no hardware support:
2-32
What am I missing??
04-10-2007 10:36 AM
You can probably lose the "flowcontrol hardware" statement: Most devices (other than modems, and virtually all Cisco gear does not use hardware handshake (no handshake at all most of the time).
The "refused" message is likely because the harware handshake is not happening (the TermServ thinks the client is refusing the connection because it can't raise the handshake line).
Modems and connections to AUX ports will use the hardware handshake.
Give it a hot and let us know.
Good Luck
Scott
04-10-2007 12:15 PM
the flowcontrol statement is on line 1 which is a modem. The lines 33 to 64 are the async lines I'm using for the console connections and I do not have that configured for those lines.
