Problems to Configure PIX 501 for Sharepoint , outlook webaccess
I try to configure my PIX 501 in order to allow remote acces to my server.
please note that this is not a VPN access, but an acces using a terminal server connection available on Windows SBS 2003.
So I would like to use Outlook Web Access an sharepoint services but I cannot connect to my server.
I try to enter these commands :
static (inside,outside) TCP interface 80 {here is my server ip}80
static (inside,outside) TCP interface 443 {here is my server ip}443
in order to route all incoming traffic (web service) to wy sharpoint server.
I also opened these ports. However it doesn't work
Can anyone tell me what to do ?
Chris
Re: Problems to Configure PIX 501 for Sharepoint , outlook webac
In addition to the statics, you will need to apply an access-list to the outside interface allowing the specified tcp ports:
access-list outin permit tcp any host 80.127.166.76 eq www
access-list outin permit tcp any host 80.127.166.76 eq https
access-group outin in interface outside
It should work after this.
Leo
Thats it !
I had to do some translations for the TCP ports 80, 443 an 135 (Outlook Web Access) and then configure access rules for these TCP ports (permit 0.0.0.0 to my server IP address, from tcp port any).
Thank you leo for yur response and thank you Tricia & Patrick from Cisco team !
Sincerely,
Chris
Well, in that case...
Thank you for rating my post
Leo
182
