05-11-2007 09:40 AM
I'm trying to configure a 1721 using the AUX port with external USR modem to dial up to a MS-RAS server as a backup. Everything dials fine and it goes through the necessary modm handshake etc.. but my async interface just disconnects/resets for somereason. Not sure if I'm missing something in my config or I have something misconfigured. Any assistance would be appreciated. I have pasted the config below with some debug outputs.
memory-size iomem 20
ip subnet-zero
chat-script DIALOUT ABORT ERROR ABORT BUSY "" "ATZ" OK "ATDT \T" TIMEOUT 120 CONNECT \c
modemcap entry MY_USR_MODEM:MSC=&F1S0=1
interface FastEthernet0
ip address 10.100.33.1 255.255.255.0
no keepalive
speed auto
interface Serial0
ip address 192.168.200.1 255.255.255.0
interface Serial1
no ip address
shutdown
interface Async5
no ip address
encapsulation ppp
dialer in-band
dialer pool-member 1
async default routing
async mode interactive
ppp authentication ms-chap chap pap callout
interface Dialer1
ip address negotiated
encapsulation ppp
dialer pool 1
dialer remote-name unified
dialer idle-timeout 300
dialer wait-for-carrier-time 60
dialer string xxxxxx
dialer hold-queue 10
dialer-group 1
ppp chap hostname xxxx
ppp chap password 0 xxxx
ppp pap sent-username xxxxx password 0 xxxx
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0
ip route 0.0.0.0 0.0.0.0 Dialer1 200
no ip http server
access-list 101 permit ip any any
dialer-list 1 protocol ip list 101
line con 0
password cisco
line aux 0
exec-timeout 0 0
script dialer DIALOUT
modem InOut
modem autoconfigure type MY_USR_MODEM
transport input all
autoselect ppp
stopbits 1
speed 115200
flowcontrol hardware
line vty 0 4
login
05-11-2007 09:45 AM
Here are some debut outputs
00:16:39: As5 DDR: rotor dialout [best] least recent failure is also most recent failure
00:16:39: As5 DDR: rotor dialout [best] also has most recent failure
00:16:39: As5 DDR: Dialing cause ip (s=10.100.33.2, d=199.0.8.1)
00:16:39: As5 DDR: Attempting to dial xxxxxxxxxx
00:16:39: CHAT5: Attempting async line dialer script
00:16:39: CHAT5: Dialing using Modem script: DIALOUT & System script: none
00:16:39: CHAT5: process started
00:16:39: CHAT5: Asserting DTR
00:16:39: TTY5: Set DTR to 1
00:16:39: CHAT5: Chat script DIALOUT started
00:17:16: CHAT5: Chat script DIALOUT finished, status = Success
00:17:16: TTY5: no timer type 1 to destroy
00:17:16: TTY5: no timer type 0 to destroy
00:17:16: TTY5: no timer type 2 to destroy
00:17:16: As5 PPP: Async Protocol Mode started for 0.0.0.0
00:17:16: As5 AAA/ACCT: Using PPP accounting list ""
00:17:18: %LINK-3-UPDOWN: Interface Async5, changed state to up
00:17:18: As5 DDR: Dialer statechange to up
00:17:18: %DIALER-6-BIND: Interface As5 bound to profile Di1
00:17:18: As5 DDR: Dialer call has been placed
00:17:18: As5 PPP: Using dialer call direction
00:17:18: As5 PPP: Treating connection as a callout
00:17:38: TTY5: Async Int reset: Dropping DTR
00:17:38: TTY5: Set DTR to 0
00:17:40: %LINK-5-CHANGED: Interface Async5, changed state to reset
00:17:40: DDR: Call disconnected, 10 packets unqueued and discarded
00:17:40: As5 DDR: has total 0 call(s), dial_out 0, dial_in 0
00:17:40: %DIALER-6-UNBIND: Interface As5 unbound from profile Di1
00:17:41: TTY5: DSR was dropped
00:17:41: tty5: Modem: READY->(unknown)
00:17:42: TTY5: dropping DTR, hanging up
00:17:42: TTY5: Set DTR to 0
00:17:42: tty5: Modem: HANGUP->(unknown)
00:17:43: TTY5: cleanup pending. Delaying DTR
00:17:43: Async5: Async protocol mode stopped for 0.0.0.0
00:17:43: TTY5: no timer type 0 to destroy
00:17:43: TTY5: no timer type 1 to destroy
00:17:43: TTY5: no timer type 3 to destroy
00:17:43: TTY5: no timer type 4 to destroy
00:17:43: TTY5: no timer type 10 to destroy
00:17:43: TTY5: no timer type 2 to destroy
00:17:43: Async5: allowing modem_process to continue hangup
00:17:44: Di1: No free dialer - starting fast idle timer
00:17:45: TTY5: restoring DTR
00:17:45: TTY5: Set DTR to 1
00:17:45: %LINK-3-UPDOWN: Interface Async5, changed state to down
00:17:46: TTY5: autoconfigure probe started
00:17:46: TTY5: Modem command: --AT&F1S0=1--
00:17:47: TTY5: Modem configuration succeeded
00:17:47: TTY5: Detected modem speed 115200
00:17:47: TTY5: Done with modem configuration
00:17:50: Di1: No free dialer - starting fast idle timer
00:17:55: As5 DDR: re-enable timeout
00:17:55: As5 DDR: rotor dialout [best] least recent failure is also most recent failure
00:17:55: As5 DDR: rotor dialout [best] also has most recent failure
00:17:55: As5 DDR: Dialing cause ip (s=10.100.33.2, d=199.0.8.1)
00:17:55: As5 DDR: Attempting to dial xxxxxxxxx
00:17:55: CHAT5: Attempting async line dialer script
00:17:55: CHAT5: Dialing using Modem script: DIALOUT & System script: none
00:17:55: CHAT5: process started
00:17:55: CHAT5: Asserting DTR
00:17:55: TTY5: Set DTR to 1
05-11-2007 11:34 AM
It looks like the modem is dropping the connection, see the DSR
Moreover I shall request you to paste output from following debugs:
1. debug modem
2. debug ppp authe
Kind Regards,
Wilson Samuel
05-11-2007 11:46 AM
Hi Wilson Samuel.Thanks for your reply. Below is the debug outputs for the mod/ppp auth only. I can't seem to make it out.
Router#debug modem
Modem control/process activation debugging is on
Router#de
Router#debu
Router#debug ppp au
Router#debug ppp authentication
PPP authentication debugging is on
Router#ping 199.0.8.1
Sending 5, 100-byte ICMP Echos to 199.0.8.1, timeout is 2 seconds:
02:44:10: CHAT5: Attempting async line dialer script
02:44:10: CHAT5: process started
02:44:10: CHAT5: Asserting DTR
02:44:10: TTY5: Set DTR to 1.....
Success rate is 0 percent (0/5)
Router#
02:44:46: TTY5: no timer type 1 to destroy
02:44:46: TTY5: no timer type 0 to destroy
02:44:46: TTY5: no timer type 2 to destroy
02:44:48: %LINK-3-UPDOWN: Interface Async5, changed state to up
02:44:48: %DIALER-6-BIND: Interface As5 bound to profile Di1
02:44:48: As5 PPP: Using dialer call direction
02:44:48: As5 PPP: Treating connection as a callout
02:45:08: TTY5: Async Int reset: Dropping DTR
02:45:08: TTY5: Set DTR to 0
02:45:10: %LINK-5-CHANGED: Interface Async5, changed state to reset
02:45:10: %DIALER-6-UNBIND: Interface As5 unbound from profile Di1
02:45:10: TTY5: DSR was dropped
02:45:10: tty5: Modem: READY->(unknown)
02:45:11: TTY5: dropping DTR, hanging up
02:45:11: TTY5: Set DTR to 0
02:45:11: tty5: Modem: HANGUP->(unknown)
02:45:12: TTY5: cleanup pending. Delaying DTR
02:45:13: TTY5: no timer type 0 to destroy
02:45:13: TTY5: no timer type 1 to destroy
02:45:13: TTY5: no timer type 3 to destroy
02:45:13: TTY5: no timer type 4 to destroy
02:45:13: TTY5: no timer type 10 to destroy
02:45:13: TTY5: no timer type 2 to destroy
02:45:13: Async5: allowing modem_process to continue hangup
02:45:14: TTY5: restoring DTR
02:45:14: TTY5: Set DTR to 1
02:45:15: %LINK-3-UPDOWN: Interface Async5, changed state to down
02:45:15: TTY5: autoconfigure probe started
Router#
05-11-2007 12:52 PM
Hello I just tested changing the async int to autodetect encap ppp and it looks like it's holding up a little bit longer but it then goes back down. I ran the same debugs and the output it a little different. Still cant' figure it out. Do you think my modem might be bad? It's a new modem fresh out of the box.
interface Async5
no ip address
encapsulation slip
dialer in-band
autodetect encapsulation ppp
03:46:16: CHAT5: Attempting async line dialer script
03:46:16: CHAT5: process started
03:46:16: CHAT5: Asserting DTR
03:46:16: TTY5: Set DTR to 1.....
Router#
03:46:52: TTY5: no timer type 1 to destroy
03:46:52: TTY5: no timer type 0 to destroy
03:46:52: TTY5: no timer type 2 to destroy
03:46:54: %LINK-3-UPDOWN: Interface Async5, changed state to up
03:46:54: %DIALER-6-BIND: Interface As5 bound to profile Di1
03:46:55: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async5, changed state to up
Router#
03:48:55: TTY5: DSR was dropped
03:48:55: tty5: Modem: READY->(unknown)
03:48:56: TTY5: dropping DTR, hanging up
03:48:56: TTY5: Set DTR to 0
03:48:56: TTY5: Async Int reset: Dropping DTR
03:48:56: tty5: Modem: HANGUP->(unknown)
03:48:57: TTY5: cleanup pending. Delaying DTR
03:48:58: %LINK-5-CHANGED: Interface Async5, changed state to reset
03:48:58: %DIALER-6-UNBIND: Interface As5 unbound from profile Di1
03:48:58: TTY5: cleanup pending. Delaying DTR
03:48:59: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async5, changed state to down
03:48:59: TTY5: cleanup pending. Delaying DTR
03:49:00: TTY5: cleanup pending. Delaying DTR
03:49:01: TTY5: no timer type 0 to destroy
03:49:01: TTY5: no timer type 1 to destroy
03:49:01: TTY5: no timer type 3 to destroy
03:49:01: TTY5: no timer type 4 to destroy
03:49:01: TTY5: no timer type 10 to destroy
03:49:01: TTY5: no timer type 2 to destroy
03:49:01: Async5: allowing modem_process to continue hangup
03:49:01: TTY5: restoring DTR
03:49:01: TTY5: Set DTR to 1
03:49:01: TTY5: autoconfigure probe started
03:49:03: %LINK-3-UPDOWN: Interface Async5, changed state to down
