Problems with Dialout-EZ and Cisco 3725 RAS Bundle
I’ve installed a Cisco 3725 RAS bundle (3725 PRI Dial Bundle: NM-30DM,NM-1CE1B, IP IOS), which works ok for incoming calls. I’ve installed Dialout-EZ in order for me to use virtual modems for outgoing calls.
I can commumicate via the virtual com port to the 3725's modems using Hyper-terminal and I can successfully run AT commands.
The problem I get is when I try to issue an ATDT command, i.e. make an outgoing call. I get NO CARRIER. I’ve checked that the ISDN30 can make outgoing calls, and according to the carrier, it can. I’ve looked at the sample configs for Cisco on the Dialout-EZ software supplier, and I appear to have set the 3725 up as recommended.
Not sure if anyone have any ideas as to why I’m getting this message!
Keith
VIP Purple
Re: Problems with Dialout-EZ and Cisco 3725 RAS Bundle
Hello Keith,
can you post the configuration of the 3725 ? Do you have the lines configured with ´modem inout ?
GP
Hi GP,
Config attached - hope this helps?!
Keith
VIP Purple
Hello Keith,
the config looks good...
Can you post the output of ´debug modem´ as well ?
There is a procedure to test outgoing calls, using reverse telnet, you might want to have a look at this document, not sure if this helps:
Troubleshooting DialOut/EZ
http://www.cisco.com/en/US/partner/products/hw/univgate/ps501/products_configuration_example09186a00800a1992.shtml#ts
GP
Hi GP,
I've attached a tracefile running debug on modem and modem trace all.
Reverse Telnet works ok and using Hyperterminal. I've included this in the tracefile also
Hope you can help?
Keith
286
