problems with ssh in 827
Hi, How can I configure to connect to my router with console and by ssh?
This is my configuration, I forgeet something but I do not know what.... using a ssh client I try to connect but always the same responde..always asking for a new pass.
Best regards
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: problems with ssh in 827
Edgar
The original post mentions being able to access the router via console and via SSH. You seem mostly to be describing access via SSH. In the original configuration that you posted it looks to me like connecting to the console should have let you righ in. When you add login and password to the console you should be able to access the console if you enter the password that you configured. Is that working or not?
SSH is for remote access. And it looks to me like the configuration should work, assuming that the key has been generated, and you say that it has. I see that the configuration has a username and password configured. Is that what you want to use to login? If so I would suggest changing the config on the vty from login to login local. This will prompt for a username and password configured on the local router. As configured I would expect it to work if you login with the password configured on the vty.
I also note that the config of the vty has access class configured which controls which addresses can access the router. Am I correct in assuming that you are accessing the router from an address that is in access list 1?
If it is still not working then running debug for SSH and posting the output would help us to figure out what the problem is.
Rick
Silver
Did you generate key for ssh?
cry key generate rsa
Detailed doc:
http://www.cisco.com/warp/public/707/ssh.shtml
line con 0
exec-timeout 120 0
login ---- ! missing
password xxx ---- ! missing
logging synchronous ---- ! not required, but cool
line vty 0 4
access-class 1 in
exec-timeout 120 0
password 7 xxxxx
login
transport input ssh
bye
FCS
Please rate me if I helped.
Hi, I have added few more lines:
line con 0 login and pass.
Rsa is already created...
I still can not login using ssh with a ssh client.....
Edgar
Rick
Hi, thaks for quickly responding
Many things:
-rsa key is already generated.
-the ip addres from i try to connect is in class 1
-the user and pass for routing administration is the same to line con 0 and vty 0 4.
I use bitvise client to connect by ssh to several devices, for example cisco routers...the banner is show when I try to connect to the 827 but it asks for pass...
best best regards
147
