PVDM + Bri Dialin problem
f.gianfrancesco
Hi everybody, i configured a c2811 with 2 bri and a pvdm module to accept incoming data connection via modem. Everything is ok except that after user is authenticated suddenly router disconnects connections with irregular time; it could be 2 mins, 5 mins etc... Anyone has an idea about? What it could be? Or if you see something wrong in configuration.
Thanks in advance, Fabio.
paolo bevilacqua
Please configure network-clock-select 1 bri 0/0/0 and network-clock-select 1 bri 0/0/1.
Hey... thanx...i try.
i will let you know.
Fabio
Hi, i tried and unfortunately nothing is changed. After 145 seconds it disconnects calls.
Have you an idea?
Thx, Fabio
Collect "debug ppp negotiaion" and "debug isdn q931" with "term mon" to see where the disconnection comes from.
