PVDM (Digital Modem) Configuration Issue
warnerjo41
I'm trying to configure a cisco 3825 (PVDM2-24DM) to connect to an analogue modem which can only run at 1200 baud. Therefore I need to fix the max/min connect speed of the digital modem's at 1200 baud. Looking at the documentation I believe I need to setup a modemcap to do this, since if you try to configure the speed on the line # it gives the message that you need to configure the speed using the AT commands. Also can anyone advise what would be best practice for setting up modem pooling, modem recovery etc. IOS V12.4
Many thanks.
Jonathan.
12 Replies 12
Makarand Chitale
Jonathan, please add the below modemcap,
conf term
modemcap edit v12_v22 miscellaneous &F+MS=1,0,1200,1200,,1200,1200
line x y
modem autoconfigure type v12_v22
Thanks, Mak
Hi Mak, Many thanks for the info, i've tried this out however it does not seem to reduce the connect time significantly, any suggestions?. Also are you aware if at document for the AT command set for the 24-port MICA modems exists? Regards, Jonathan.
Jonathan, is it the connect speed (1200 baud) or the connect time that you are looking for? We will need to use different AT commands to achieve them.
I think you are looking for AT commands for the PVDM2 digital modems and not MICA - correct?
AT Command Set and Register Summary for Cisco PVDM2 Digital Modems
http://www.cisco.com/en/US/docs/routers/access/pvdm/at/command/reference/atpvdm2.html
Just adding MICA as well in case you want it:
AT Command Set and Register Summary for Cisco MICA Six-Port Modules
http://www.cisco.com/en/US/docs/routers/access/modem/AT/Command/reference/atcmnds.html
Thanks, Mak
Hi Mak,
Many thanks for the documents; however we would like to try to speed up the connect time to our 1200 baud modems, any suggestions? we are clearly connecting at 1200 baud since if you do a "show modem connect-speed" we see entries against 1200 baud. Currently if takes about 10-15 sec to make a successful connection.
Jonathan.
Hi Mak, one of our field engineers is asking what condition would cause the Async ports to be 'Administratively DOWN' since this is occuring a number of times?
Jonathan.
'Administratively DOWN' condition on the first of two ports I use - Async0/322.
ciscodeb#show interface Async0/322
Async0/322 is administratively down, line protocol is down
modem(slot/port):0/322, csm_state:IDLE_STATE,
bchan_num:-1 csm_status(0): CSM_STATUS_UNLOCKED
ciscodeb#show interface Async0/323
Async0/323 is down, line protocol is down
modem(slot/port):0/323, csm_state:IDLE_STATE,
I would be happy to know whether there are any internal mechanisms in cisco which would put the port into Down status
Hi Mak,
I've purchased 2 Cisco 1841 routers and a Cisco 2811. The 2811 is equipped with a HWIC-2CE1T1-PRI and a PVDM2-24DM module and will serve as a RAS. The 2 1841 will serve as remote access routers dialing the 2811 via an external Multitech modem. I've successfully set up the dial up between the 1841s. Clients sitting behind these two 1841s can reach each other and continuous pings get replied. However, the servers behind the 2811 seem unreachable. The Calling Switching Manager of the 2811 shows calls being disconnected and PPP debugging don't show that PPP phases are at all reached. I'd very much appreciate tips as to what could be wrong. I followed the examples in http://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/htpvdm2.html#wp1077402 and http://www.cisco.com/en/US/docs/ios/dial/configuration/guide/dia_cfg_isdn_pri_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1002870.
Below's my configuration:
Current configuration : 6901 bytes
! No configuration change since last restart
version 12.4
hostname pstnrouter
boot-start-marker
boot system flash c2800nm-advsecurityk9-mz.124-15.XY1.bin
boot-end-marker
card type e1 0 2
logging buffered 51200 warnings
enable secret cisco
aaa new-model
aaa authentication login default local
aaa authentication ppp default local
aaa session-id common
network-clock-participate wic 2
network-clock-select 1 E1 0/2/0
network-clock-select 2 E1 0/2/1
modem country v12 e1-default
ip cef
no ip domain lookup
ip domain name genius.com
isdn switch-type primary-5ess
spanning-tree uplinkfast
spanning-tree backbonefast
username cisco password 0 xxxxx
controller E1 0/2/0
linecode hdb3
framing crc4
pri-group timeslots 1-31
controller E1 0/2/1
interface Loopback0
ip address 1.1.1.250 255.255.255.255
interface Loopback1
ip address 172.16.100.250 255.255.255.255
interface Loopback2
ip address 172.16.30.254 255.255.255.0
interface FastEthernet0/0
ip address 10.199.199.250 255.255.255.0
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
interface FastEthernet0/3/0
switchport access vlan 12
interface FastEthernet0/3/1
interface FastEthernet0/3/2
interface FastEthernet0/3/3
interface Serial0/2/0:15
no ip address
encapsulation ppp
isdn incoming-voice modem
no cdp enable
interface Vlan1
no ip address
interface Vlan12
ip address 172.16.12.250 255.255.255.0
ip nat inside
interface Dialer0
ip unnumbered Loopback2
encapsulation ppp
dialer pool 1
dialer idle-timeout 300
dialer-group 1
no cdp enable
interface Group-Async0
no ip address
encapsulation ppp
load-interval 30
dialer in-band
dialer pool-member 1
async mode dedicated
no peer default ip address
group-range 0/322 0/345
router ospf 1
log-adjacency-changes
redistribute static subnets
passive-interface FastEthernet0/0
network 10.199.199.0 0.0.0.255 area 0.0.0.0
network 172.16.0.0 0.0.255.255 area 0.0.0.0
dialer-list 1 protocol ip permit
line con 0
line aux 0
line 0/322 0/345
modem InOut
transport input all
transport output all
end
Hi, you may want to open a new thread for the different problem and include the debug output for the failed PPP connection.
Hi Paolo,
I should have thought of opening a new thread. After 5 days of trying to sort out this problem and the fact that it was my first time using the forum, I just dived into a thread I thought is related to my query.
By the way, I finally found the cause of the problem. We bought a PSTN simulator from the US. I rechecked the simulator settings morning only to find out that although I've selected Euro E1 PRI ISDN, the default compression algorithm on the simulator is u-Law (used in USA and Japan). Euro PRI ISDN uses A-Law. Changing that and selecting primary-net5 ISDN switch solved the problem.
Hi, it's bit strange because the compaund type is carried in the call setup and the router normally adapts without the need to configure anything.
But good that you've resolved the issue anyway.
Could it be that the simulator doesn't emulator the 5ESS properly?
Hi, can you recommend some books that cover Cisco PRI ISDN and PVDM configurations in more depth? During this project, for which I'm the configuration engineer, I came across config techniques/topics that are not covered in my CCNA and CCNP books.
One should look at a call trace to tell.
I think some cisco book do cover these things, but in telecom and networking there is no substitute for reasoning ans experience.
