QoS on 2821/1801 with WIC-1ADSL
nrmdcs
I'm trying to implement CBWFQ, WRED and traffic shaping on an ADSL service. I'm only using the default class in the Child policy at this stage, but will expand to more later. Can I use the Parent/Child model and if so where do I apply the service-policy output Parent command?
If I can't use Parent/Child to perform the shaping and CBWFQ/WRED, I suppose I need to use ubr/vbr etc on the ATM PVC to perform the shaping. But if I do that, where to I apply the CBWFQ/WRED policy?
Please see config below:
interface atm0
description ATM Interface
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface dialer0
ip address negotiated
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname XX
ppp chap password XX
policy-map Child
class class-default
fair-queue
random-detect dscp-based
policy-map Parent
class class-default
shape average 400000
service-policy Child
10 Replies 10
pkhatri
Level 11
Level 11
You need to shape on the ATM PVC and then apply the child policy under the 'pvc 8/35' configuration level as below:
interface atm0
pvc 8/35
service-policy output Child
There is no need (or support) for a shaping parent policy because the shaping will be done at the ATM level.
Hope that helps - pls rate the post if it does.
Paresh
Thanks for your prompt reply Paresh.
I've done as suggested and configured vbr shaping on the pvc and added the Child policy. However, when I do sh policy-map int I get nothing...?
Jon
Can you post your config ?
Paresh
Important bits below:
boot-start-marker
boot system flash flash:c2800nm-advipservicesk9-mz.124-3b.bin
boot-end-marker
policy-map Child
class class-default
fair-queue
interface ATM0/0/0
description ADSL Service
bandwidth 399
no ip address
load-interval 30
no atm ilmi-keepalive
dsl operating-mode auto
pvc 8/35
vbr-nrt 512 399 3392
interface Dialer0
description PPP Session
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
dialer pool 1
ppp chap hostname xx
ppp chap password xx
Hmmm... that all seems to be in order, mate. So the command you entered was 'sh policy-map interface atm0/0/0', wasn't it ?
Paresh
Yeah, and 'sh policy-map int' by itself...might upgrade the IOS and see what happens.
Jon
I've upgraded to the latest IOS, but still no good. Even though the shaping is configured on the atm vc, should the policy map be put on the dialer int?
I suspect that might be the case, since the ATM interface is being used purely as a physical interface and the dialer interface is the logical interface here...
Paresh
Actually, I'm not sure if that is correct.... you should still be able to apply a policy to the ATM interface.
One thing that concerns me is the abnormally high value of MBS that you have used. What's the reason for that ? Is it possible that you could set it to something like 1 and see if that makes a difference ?
Paresh
The MBS was an error on my part, I had it configured in bits instead of cells. It's now 64 cells, however no change to policy map. Although the dialer int will take the command and show up in a sh policy-map int, I'm concerned that the congestion backpressure from the atm int will not be passed to the dialer ints layer three queues and the CBWFQ/WRED will not kick in. Haven't tested it yet though.
