QoS on ATM DSL interface
jaregalado
using the document "QoS Solutions for PPPoE and DSL Environments" as a reference I'm trying to implement Quality of Service for a DSL connection via the ATM interface on a 2821 router.
So I apply the service-policy under ATM VC configuration mode (PVC 8/35) and the command is accepted with no complaints, but when I do a show run, I realize the command is not there:
interface ATM0/0/0.1 point-to-point
pvc 8/35
encapsulation aal5snap
pppoe-client dial-pool-number 1
end
Any Idea why is this happening ?, we have version 12.3(14)T7. Is this the right way to configure QoS for DSL, or should I configure QoS on the dialer interface instead ? Any suggestions are welcome.
The document I checked can be found here.
http://www.cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a00800b2d29.shtml
Regards.
6 Replies 6
spremkumar
Level 9
Level 9
hi
Can you user show policy-map interface command to check whether your service policy has been binded under the ATM interface ? can you also post the output for the command here ?
regds
Hi, of course,
whenever I try to configure a service-policy under pvc mode as recommended on the Cisco docs the command is accepted but it just doesn´t show up in the final config, also using the command you mentioned I can clearly see that the policy is not operational:
rtr#int atm0.1 point
rtr(config-subif)#pvc 8/35
rtr(config-if-atm-vc)#service-policy output QoS-Policy
rtr(config-if-atm-vc)#exit-vc
rtr#show policy-map interface
rtr#
This happens on a 2821 router with version 12.3(14)T7 but also happens on a 877 router
with version 12.3(8)YI2
Worth to mention is the fact that the command is accepted and seems to work Ok on the
877 router under atm main interface mode:
rtr#sh running-config interface atm 0
Building configuration...
Current configuration : 120 bytes
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
end
I can clearly see that the policy is in effect:
ATM0
Service-policy output: QoS-Policy
Class-map: VoIP-RTP (match-any)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: protocol rtp audio
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name VoIP-RTP
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
Strict Priority
Output Queue: Conversation 40
Bandwidth 80 (%)
Bandwidth 102 (kbps) Burst 2550 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
QoS Set
dscp ef
Packets marked 0
Class-map: VoIP-Control (match-any)
0 packets, 0 bytes
Match: access-group name VoIP-Control
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
Output Queue: Conversation 41
Bandwidth 5 (%)
Bandwidth 6 (kbps) Max Threshold 64 (packets)
(depth/total drops/no-buffer drops) 0/0/0
QoS Set
dscp af31
Packets marked 0
Class-map: class-default (match-any)
189 packets, 32032 bytes
5 minute offered rate 2000 bps, drop rate 0 bps
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 32
(total queued/total drops/no-buffer drops) 5/0/0
However the 2821 router oddly doest´n accept policies under atm main interface mode... (???)
rtr2#interface atm 0/0/0
rtr2#service-policy output QoS-Policy
CBWFQ : Not supported on this interface
Any ideas ?
Best regards.
I believe it is very important to apply the service policy under/after the VCI/VPI because you want it applied to the individual VC not the physical interface.
Sometimes when a virtual-template is created you have to configure it there.
Rate if this helps.
Mike
wochanda
Level 4
Level 4
You cant apply a QoS policy to an ATM PVC without traffic shaping configured. Best (and most often configured) ATM traffic shaping is vbr-nrt. Basically you plug in your upload bandwidth and it'll traffic-shape you to that rate. More importantly, it helps the QoS schedule allocate bandwidth for the various classes.
Do the following:
interface atm0/0/0.1
pvc 8/35
vbr-nrt 768 768
tx-ring-limit 5
Once you exit out of this, the command should have stuck, and you'll be able to issue a 'show policy-map interface atm0/0/0.1'.
If you're upload speed isn't 768k, change the vbr-nrt statement to whatever the speed is, in kbps.
You may also notice I put in a tx-ring-limit command. This is needed to create backpressure from the module to the router, telling it to use the QoS classes you have configured.
Do you have any links that might help explain this.
Is this the case for all ATM interfaces?
Mike
