Community Member
"load balancing" over ADSL
Using a router (Cisco 2811) with 4 ADSL links connected to the same ISP, is it possible to implement ‘load balancing’ or similar feature ?
Thanks in advance
Jvaidie
1 REPLY
Re: "load balancing" over ADSL
hi
Do revert about the local lan subnets and the ip address being assigned to all 4 links by the SP.
Also whether all the 4 links are connected on the same router (2811) or on different routers ?
in normal scenario where u gotta 4 links on the same router since its gonna be simple internet traffic outgoing traffic can be placed over all the 4 links as per your requirement.
For that we need to have 4 static routes without any admin distance attached to it.
that will take care of putting ur load on all the 4 links since the router will see 4 equal cost links to go out.
regds
216
