Community Member
Rate limit a certain pvc on an ATM interface on DSLAM
Dear Sir
I want to rate limit a certain pvc on an ATM interface on DSLAM 6260, Taking into consideration that i have tried all the kind of configuration using the rx-cttr and tx-cttr but all was useless.
Could you please guide me how to do that, especially if i have a multiple pvcs on the same ATM interfaces and i need each not to raise above certain limit?
Thanks in advance
Silver
Re: Rate limit a certain pvc on an ATM interface on DSLAM
Which IOS version u are using?.There are several new IOS versions released with many advanced features.I want to know ur cisco IOS version, with which i can determine whether ur IOS supports this per pvc rate limitation.
Community Member
Dear Sir
First thank you for your reply and concern.
Here is the version 12.2(12)DA8 as i told you it is a Cisco DSLAM 6260 with NI-2, and as i got from the TAC that it is the latest (as far as i know).
Thanks a lot
211
