Redirecting SSL VPN to public DMZ interface
I have a situation where the usable WAN IP block belongs to the DMZ interface of the ASA. A WAN/ISP transit network also exists between the ASA and ISP provider but we cannot use these addresses for SSL VPN.
Is it possible to route through the WAN/ISP interface and terminate SSL client/clientless connections on the DMZ interface of the ASA?
Re: Redirecting SSL VPN to public DMZ interface
I am confused - why do you think "A WAN/ISP transit network also exists between the ASA and ISP provider but we cannot use these addresses for SSL VPN" If it is reachable from the Internet and there is an IP address on the "outside" interface address of the ASA - then you can use it.
HTH>
We cannot use it as 443 is utilized for another purpose on that IP.
yes it would fail if you have not configured the device to accept WebVPN connections on that interface??
webvpn
enable >
HTH>
243
