reg:pri module
Dear sir,
We need a router and 8 port PRI module.
8port pri odule which router will support.
Thanks&Regards
srini
1 REPLY
Re: reg:pri module
A NM-8CE1T1-PRI will provide 8 Channelized PRIs. The lowest platform to support the NM-8CE1T1-PRI is the 3825.
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/product_data_sheet0900aecd80710c88_ps5949_Products_Data_Sheet.html
Depending on what you're trying to do, the MFT card might work too (cheaper).
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800f9d37.shtml
Hope that helps.
164
