Relation between RADIUS - ISDN
How is the relation between the RADIUS protocol and ISDN protocol? The AS receives a disconnection message from RADIUS and translate to ISDN, but how it
occurs? There is a table that make it?
I need to configure the RADIUS server to send correct disconnection message to AS.
Thanks.
1 REPLY
Hall of Fame Super Gold
Re: Relation between RADIUS - ISDN
For data calls, you cannot disconnect with a specific cause on your side. The AS will always use "normal call clearing".
This is also why the ISDN standard doesn't not have cause like "wrong password", "session limit exceeded" or other things related to PPP.
128
