Remote access telnet to Router is not working
frank2812
Even though the router is configure to accept  telnet connection we can not connect. I atached the sh run  of the Router. We can do ping to the router. I proved doing telnet from inside the same router but is not working like you can see in the logs down here. i proved telnet from diferent devices but is not working.
Dayco-CPA#192.168.13.1
*Dec  6 14:16:58.437: %FAN-3-FAN_FAILED: Fan 1 had a rotation error reported.
Trying 192.168.13.1 ...
% Connection refused by remote host
Rolf Fischer
Level 9
Level 9
Franklin,
the exec-timeout is 0, so maybe all the vtys are just in use and never time out.
Could you check this with show line vty 0 4 and clear the lines if necessary?
Saludos
Rolf
[EDIT]:
R1#telnet 1.1.1.1
Trying 1.1.1.1 ... Open
R1#telnet 1.1.1.1
R1#telnet 1.1.1.1
R1#telnet 1.1.1.1
R1#telnet 1.1.1.1
R1#telnet 1.1.1.1
Trying 1.1.1.1 ...
R1#show line vty 0 4
   Tty Typ     Tx/Rx    A Modem  Roty AccO AccI   Uses   Noise  Overruns   Int
*   130 VTY              -    -      -    -    -      6       0     0/0       -
*   131 VTY              -    -      -    -    -      5       0     0/0       -
*   132 VTY              -    -      -    -    -      4       0     0/0       -
*   133 VTY              -    -      -    -    -      4       0     0/0       -
*   134 VTY              -    -      -    -    -      2       0     0/0       -
R1#clear line vty 3
[confirm]
[Connection to 1.1.1.1 closed by foreign host]
5 Replies 5
Rolf Fischer
Level 9
Level 9
Franklin,
Saludos
Rolf
[EDIT]:
R1#telnet 1.1.1.1
R1#telnet 1.1.1.1
R1#telnet 1.1.1.1
R1#telnet 1.1.1.1
R1#telnet 1.1.1.1
R1#telnet 1.1.1.1
Trying 1.1.1.1 ...
R1#clear line vty 3
[confirm]
I thought the telnet gets timed out ?
Well, it does; by default after 10 minutes inactivity.
But in this case the exec-timeout was set to zero, which means it never times out.
http://www.cisco.com/en/US/docs/ios/12_2/configfun/command/reference/frf004.html#wp1017909
Rolf
yeah sure,
then i don't think of any reason why we are not able to telnet
Franklin, try that , removing the no ecex-timeout command and kill all the current telnet sessions
lets see...
amsodhi
Output is pointing the issue with hardware.
I would like to do some bug scrub, please share show version output.
Also let me know, if it works fine from console.
-Amant
