remote connection established - delayed ping responses - why??
When we have established a remote session with Cisco RAS it takes a long time - 30 secs to a minute - until we start to receive ping responses from a server on the network. Any ideas?
Bronze
Re: remote connection established - delayed ping responses - why
There is nothing wrong with the configuration because connection is established. With Ping command the normal response occurs in 1 to 10 seconds, depending on network traffic. But in you case it is taking more than 30m sec. this may occur due to big length cable use or traffic. To determine if ping is getting delay looked at the CPU.
We have checked CPU which is at around 3% so that should not be causing it.
Also you state that with the ping command it is normal not to receive a response within 1 to 10 secs. Why is this?
233
