Webcast-Catalyst9k
Remote desktop through ethernet0/1
Good day, I would apreciate it if somebody would like to help me set up our new router. The ISP is not very helpful. I got it connected to the net with some functionalty but I can not send mail througt the router it sais something like Relay not permited from your location. And i cant seem to get remote desktop working through the Ethernet 0/1 port. I will attach a network diagram with basic information. It any one needs more info I will suply it. PLZ Help.
Re: Remote desktop through ethernet0/1
attach your sh run output. If you can't connect with remote desktop outside probably you haven't configured port mapping correctly.
Here is my running config. (see Attachment)
Thank You
check you access-list 1 it's incorrect in this part
access-list 1 permit 0.0.0.1 196.25.155.158
make sure access list allow access host from FastEthernet0/1 network translated because this interface is ip nat inside.
148
