Remote loging
soumik1979
We are having own intranet system at our organization with LAN IP 192.168.0.0/24.We are having an internet leased line with cisco 1841 and ASA 5510.I want to know that is it possible to connect the intranet or our local network from outside through internet.If yes how???Please discuss...
drolemc
Level 6
Level 6
Yes you can do this setup through VPN. Basically, a VPN is a private network that uses a public network (usually the Internet) to connect remote sites or users together. Instead of using a dedicated, real-world connection such as leased line, a VPN uses "virtual" connections routed through the internet from the company's private network to the remote site or employee.
Ya.But how this can be done.Do you have any documents regarding that..
Hi, I would recommend you hire a qualified techncian for this, as even if an apparently simple task, can become very frustrating for a non cisco certified person.
