remote
hello I small problems I Cisco router 800 serials now I remote wants work by means of SSH and telnet now are my question how can you this do?
who can help me
4 ACCEPTED SOLUTIONS
Re: remote
You should be able to telnet to the router on the WAN/external ip address remotely if telnet is not disabled.
For SSH, you have to generate RSA keypair before you can SSH to the router. Here is the sample configuration for SSH:
http://www.cisco.com/en/US/customer/tech/tk583/tk617/technologies_tech_note09186a00800949e2.shtml
Hope that helps.
Re: remote
sorry, i don't quite understand what you mean.
Telnet locally works, however, telnet from external is timing out?
Are you getting the password prompt when you try to telnet from external? If not, then there is probably access-list on the interface that blocks telnet, OR/ under "line vty", it's only allowing internal address range.
Re: remote
do you have a copy of the router configuration? I can check and let you know what to add/change.
Re: remote
I don't understand what you mean.
Re: remote
Hope that helps.
Re: remote
no telnet are not disabled. because is possible inlogen local but externally succeed that because krijg time out must there sometimes something to fit become?
Re: remote
Re: remote
yes that is correct telnet local works but externally does not work it how can you that access trick make for telnet?
kind regards
Re: remote
Re: remote
yes I have copy of running-config
possible you is something lets know what be adapted there must?
Re: remote
OK, base on the configuration, you have ZBFW (Zone Base Firewall) configured. Hence you would need to allow the traffic between out-zone and self-zone.
Here is what you would need to configure to allow telnet access:
class-map type inspect match-any telnet-class
    match protocol telnet
policy-map type inspect ccp-permit
    class type inspect telnet-class
        inspect
Hope that helps.
Re: remote
yes it works external telnet cordial thanks
do you know sometimes how that with SSH also are possible?
kind regards
Re: remote
Sure, for SSH just add this:
    match protocol ssh
Re: remote
there does this have still something changes become?
kind regards
Re: remote
You would also need to generate the RSA keypair: crypo key generate rsa
You also need to use SSH Client software (eg: Putty, SecureCRT) to SSH to the router.
Re: remote
those RSA key I have produced and used putty must still something change become?
kind regards
Re: remote
Mmmm.. where does it break?
Are you able to telnet on port 22?
Are you prompted for username and password?
Or the connection just hang?
Can you share the latest configuration again pls.
Re: remote
yes that is no problem this is new running-config
I have telnet geprobeert as from another isp and then work
mvg
Re: remote
I didn't see your SSH configuration on the ZBFW.
Please configure the following
class-map type inspect match-all ssh-class
match protocol ssh
          inspect
Re: remote
on this small file is correct has it done that a little?
kind regards
Re: remote
That configuration looks OK. It should work now.
Re: remote
no it not yet works because if I take another isp I do telnet SSH connection then get I time out?
kind regards
Re: remote
not sure what you mean by another ISP?
Can you SSH to it locally?
Re: remote
I my postages have let check on gateway 22 (SSH) 23 (telnet) and that am closed how you can open that
Re: remote
I don't see 2 ISP on your configuration. Your configuration only says gig0 as the external interface.
Re: remote
Re: remote
Re: remote
the postage 22 is closed same the postage 23 is closed how is possible you that open putting?
kind regards
Re: remote
the postage 23 is closed on the router can you the postage open?
kind regards
Re: remote
kind regards
652
