Community Member
Reverse telnet to Cisco router async serial port unstable
I have a 3640 Cisco router that is connected to an EF Johnson communication device's console port. The router is connected using a serial port (NM-4A/S) and Cisco RS232 serial cable.
I have configured the router's serial port to async mode (physical-layer async) and set the async line to -
transport input telnet
transport output telnet
speed 2400
stopbits 1
Using the configuration above, I manage to reverse telnet to the serial port and access to the EF Johnson's console port login prompt. I could perform some basic functions once login but when I tried to perform a file upload (into the EF Johnson device), it failed halfway.
The file uploading works fine if I connect to the EF Johnson device through a modem dial-up line. I connect a modem to the device and another modem to my PC. From my PC, I initiates a dial-up to the EF Johnson modem and logs in. The modem connection is established using 9600bps, 8 databits, 1 stopbit and no parity.
Need all the help I can get.
Thank you.
1 REPLY
Hall of Fame Super Gold
Re: Reverse telnet to Cisco router async serial port unstable
Already replied in WAN forum.
463
