Routing between two VPN tunnels ( Hairpinning)
sanjay.ccie
I have three sites A,B and C
Site B terminates 1 S2S VPN tunnels from site A and site C each.
The Vpn tunnels are up. I need to route traffic from site C to Site A and vice-versa. I also need to Nat the traffic from site C to site A at site B.
I am using cisco 2800 router at site B.
Where can I get a cofiguration example for this?
Please help with any Idea.
Collin Clark
http://www.cisco.com/en/US/tech/tk583/tk372/tech_configuration_examples_list.html
PIX to PIX is about half way down the page.
Hope it helps.
Hi thanks for you reply,
However routers do not support same interface natting so I have to use nat on a stick.
