Routing lost after a few seconds...
gtsesmelis
Hello everybody.
The setup is the following :
2811 router with ISDN-BRI interfaces and a WIC-1T.
The WIC-1T intf connects via an RS-232 cable to an external Motorola modem.
When remote users dial-in establishing an ISDN connection everything is fine.
When calls come through analog modem connections, call gets established, and PPP negotiation completes successfully.
At that instant and for a few seconds, the (analog) user has network connectivity (at this point tried by continuous pings).
"Suddenly" replies stop!
Only after disconnecting the call and re-connecting (temporary) routing is reestablished, to get lost again in a while !!
We have tried with-and-without Group-Async (config directly to the Serial intf) but nothing changed.
Any ideas, anyone ?
The current config - for anyone interested and after many try-outs - is attached...
Thanx in advance.
George
Pravin Phadte
Level 5
Level 5
hi,
If you could provide the debug q921 and 932 it would be great.
Problems seems to be with authendiation
As i already mentioned the problem is on the analog connection and not on the isdn.
gtsesmelis
The problem is solved...
