Routing to another Network when on VPN
Hi, the setup is HQ site have VPN client connectivity to PIX 515 and clients get IP address of 172.16.0.x they can access resources within HQ network 172.16.0.x
A branch office has network address 192.168.0.x which is unreachable to those connected to HQ by VPN. HQ and Brach office have a VPN tunnel between them so users within both networks can access each resources in the other site. How can this be done for those connected to HQ by VPN?
Thanks for any advice
Re: Routing to another Network when on VPN
do you have an IPSec VPN between both your PIX firewalls ? It might be easiest if you post the configuration of both your PIXs...
GNT
Yes there is an IPSec VPn between both. As one of the configs is so big in terms of number of lines in it you might loose the will to live when trying to read it!
large configs = no problem ! It is just easier to see what you might be missing when looking at the entire configuration...:)
GNT
113
