serial port on router with 4MB bandwidth
Hi everybody
I know that wic solt has serial port with 2mb speed but someone aksed me about port with 4mb bandwidth .could you pls help me that what module I can select?
thanks
Re: serial port on router with 4MB bandwidth
what you are looking for is a high speed serial card (HWIC), which support speeds up to 8Mbps. Have a look at the link below, it lists the HWICs for the 1800/2800/3800 series:
http://www.cisco.com/en/US/products/ps5949/products_data_sheet0900aecd80274416.html
HTH,
GNT
Which router are you having?
JD
For the 72xx routers you can use a PA-4T / PA-4T+ card. This is 4 ports x 2Mbps. It is possible to do "aggregation" there. If you use only 1 port from the entire card, you can set it up to 8Mbps. If you use 2 ports from the card, you can set them to 4Mbps each.
There is a similar card NM-4T for the 36xx series routers.
In several circumstances the WIC-2T card also can support 4Mbps and 8Mbps.
Read this link:
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800b0858.shtml
Do not use X.21. Go for V.35 or RS-449.
That is due to clocking limitations.
263
