Community Member
SHDSL using an external modem
Just wondering if it is a possible to configure a Cisco 2611XM for SHDSL using an external modem such as the RAD product ASMi-52 which does the line sync for you.
The CHAP authentication needs to be done by the router behind it (2611XM in this case).
I've never done this without a wic, any help would be greatly appreciated.
1 ACCEPTED SOLUTION
Re: SHDSL using an external modem
You need to do chap on the router. Chap is a ppp authentication method hence it is logical to assume that you will be using ppp and while you do this via the router's ethernet port it must be PPPoE.
Please check the config example below:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1834/products_feature_guide09186a00800800f4.html
Leo
You will need to configure PPPoE. Please check the general technology page for any usable info or configuration examples:
http://www.cisco.com/en/US/tech/tk175/tk819/tsd_technology_support_protocol_home.html
Leo
Community Member
Hi Leo,
Is PPPoE used for SHDSL? sorry for the silly question !
A standard SHDSL connection with a WIC looks like this:
interface ATM0
no ip address
no atm ilmi-keepalive
dsl equipment-type CPE
dsl operating-mode GSHDSL symmetric annex B
dsl linerate AUTO
interface ATM0.1 point-to-point
description INTERNET
pvc 1/34
ubr 1024
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname xxxxxxxxx@xxxxxx
ppp chap password xxxxxxxxxx
crypto map mymap
In my scenario, I'm not using the WIC, so I'm a bit confused as to how the configuration shouyld like as I have no ATM interface.
Leo
Community Member
Got it, thanks Leo.
The SHDSL provider also only uses PPPoA, but it worked. Thanks again.
289
