ssh and telnet to remote router
pcfreak49
hello I have a question know there sometimes someone how your SSH and telnet configure router to remote ?
all tips are welcome
17 Replies 17
Jennifer Halim
Do you mean that you are trying to SSH/telnet to the router remotely?
If that is the case, by default SSH/telnet should be enabled unless you disable it.
Check the configuration under "line vty 0 4", you should have a line that says "transport input all" which allow both SSH and telnet.
For SSH, you would need to generate RSA keypair before you can SSH to it.
For telnet, you can just telnet to it directly.
Another configuration that you might want to check is if there is any ACL applied to the interface, or line vty, and/or if there is any Zone base FW configuration.
Hope that helps.
yes that wants try on the line vty 0 4 transport input telnet SSH
the RSA key are generate on 1024
with telnet am not possible I remotly
I hope that someone can help me please
i
paolo bevilacqua
You have asked this same question already, but you have failed to explain what do you want to do actually.
You also have receivied a very valuable answers, again you have failed consider or understand.
Please do not open thread doplicates, and explain what you want to do in plain english.
I none English but Dutch for becomes the text translates
who can help me for configuring remote telnet and SSH
all tips are most welcome
Post your configuration here.
I suspect you are using "any any" in NAT ACL - wrong.
here my running-config are
if there is must be adapted must
it would be possible me that to leave
to know because will very gladly have that it works it is for my studies
kind regards
Configure:
interface GigabitEthernet0
no ip virtual-reassembly
no zone-member security out-zone
interface Vlan1
no ip flow ingress
no zone-member security in-zone
no ip tcp adjust-mss 1452
oke that are geconfigureert these are the new running-config must there still something to fit become sometimes?
kind regards
On interface GigabitEthernet0, do you receive a public or privateIP address ?
interface GigabitEthernet0, receive a public
Can you ping it from outside?
What happens when you try telnet or SSH to it ?
I can ping from outside do public address
I want telnet and SSH on do Cisco router for remote in at lay
What happens when you do SSH or telnet to router ?
I get time out
