Telnet connection---urgent pls
each time i try to telnet using my LAPTOP.I get command not recognised.can somebody help me out now.Other PC works except mine.This is very urgent pls.
Silver
Re: Telnet connection---urgent pls
Download Putty
Search on google " Putty ".... using putty telnet.
You can open Hyperterminal and choose TCP/IP option instead of COM1.
Click on OK
You will telnet into device.
Putty use is very good very secure.
Dharmesh Purohit
Silver
go into c:\windows\system32
See there telenet.exe... otherswise download telnet.exe and put it on above path.
Dharmesh Purohit
If you are using Windows Vista Telnet is not installed by default. Go Control Panel, Programs and Features to install it. However, I agree that Putty will work better for you in the long run and give you other features/capabilities as well.
Thank you so much for your apt response.I will keep you posted.
I really appreciate your prompt response to my posting.
Cheers....
137
