Tying a modem (or Group-Async) to a specific physical PRI?
philip.neeson
In our lab we have a 3600 with a bank of mica modems and 2 * PRIs. We want all calls to PRI#1 to go to Group-Async1 and all calls to PRI#2 to go to Group-Async2. Is this possible and how can it be achieved? We are running 12.3 but code upgrades aren?t an issue.
The dialer pool / dialer pool-member doesn't seem to be an option. Incoming calls terminate on line 33 and then rotate in sequence to line 44 and back to 33.
Our basic config is;
controller E1 0/0
pri-group timeslots 1-8,16
controller E1 0/1
interface Serial0/0:15 <<-- We want this to terminate on group-async 1
no ip address
isdn switch-type primary-net5
isdn incoming-voice modem
interface Serial0/1:15 <<-- We want this to terminate on group-async 2
no ip address
interface Group-Async1
no ip address
dialer in-band
async mode dedicated
group-range 33 38
interface Group-Async2
no ip address
dialer in-band
async mode interactive
group-range 39 44
line 33 44
login local
modem InOut
transport input all
Any ideas?
Philip.
ljohns
You need to use DNIS and Modem pools. Here is an example configuration. For full details please go to the link listed below. The link is set up for CAS but it is the same for ISDN PRI.
http://www.cisco.com/en/US/partner/tech/tk801/tk36/technologies_configuration_example09186a0080093c2c.shtml
Configuration with One Modem Pool
In this example, only one modem pool is configured with one modem:
modem-pool part1
pool-range 1
called-number 4085551345 max-conn 1
controller T1 0
framing esf
clock source line primary
cas-group 0 timeslots 1-24 type e&m-fgb dtmf dnis
