Community Member
UK - 857 With BT ADSL MAX - Lines become unstable and router require FW upg
We are starting to see a number of DSL MAX sites running 857 routers becoming unstable, constant loss of sync, re-authentications etc - sometimes up to 400 a day. We called out the Telco (BT) and they tested the line as OK and stable. After swapping the kit three times I spoke with TAC and they provided me with a newer version of the ATM Firmware (2.6.4) - This fixes the problem and stabilises the line.
My question is - Has anyone else seen this problem in the UK? Are BT rolling out a code upgrade to their DSLAMs or changing some hardware? Is this likely to affect all UK DSL MAX connections in the near future?
Andy.
Re: UK - 857 With BT ADSL MAX - Lines become unstable and router
Hello Andy,
there was an issue in the past with Cisco 837 and I think 857 routers, with a possible solution being to set the 'dsl operating mode' to 'ansi-dmt' instead of 'auto'. You might want to give this a try and see if it makes a difference...
GNT
Community Member
Andy,
We've likewise seen issues with Cisco 870 routers on BT ADSL lines. I doubt that BT will do any upgrades to their DSLAMs as we've found them pretty unhelpful when it comes to DSL. We're currently rolling out a lot of 870s and I'm going to be upgrading firmware on all of them before deployment.
Cheers,
Neil
190
