Unable to add dialer-group 1 to interface
darren.shady
Greetings,
Here's the following config from a router currently on Dialbackup into my AS5300.
interface Async0/1/0
no ip address
encapsulation ppp
no ip route-cache cef
dialer in-band
dialer pool-member 1
dialer-group 1
async mode dedicated
interface Dialer1
ip address 10.14.55.113 255.255.255.252
encapsulation ppp
no ip route-cache
dialer pool 1
dialer idle-timeout 25
dialer string 1-800-000-0000
dialer watch-group 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
I am unable to use the same config on other 1841 with the same WIC-1AM cards. I receive the error "%Remove Dialer Profile Configuration first".
"Router(config)#int async0/1/0
Router(config-if)#dialer-group 1
I am puzzled. This is a working config. I am using dialer-watch list. The dialer isn't binding because the hardware, async0/1/0 and the dialer1 aren't in the same dialer group? I cannot get the DDR to come up and dial out now. This is only difference between sites able to dial and sites that aren't
Help!
6 Replies 6
Richard Burts
Darren
You have not told us what kind of router and what version of IOS generated the working config. And you have not mentioned what version of IOS is on the 1841. Those details are potentially helpful.
I am guessing that the version of software running on the 1841 defaults something into the config that makes it believe that there is a dialer profile which it wants removed. Perhaps if you were to post the complete config from the 1841 where it does not work, we might find some explanation.
Rick
Rick
12.3(11) Advanced Enterprise Edition
I've attached a config minus IP, Access Lists and passwords.
I've attached a working config, pulled right from a site dialed in. Both 1841's are running the same IOS and same WIC cards
Darren
It still has the feeling to me like an IOS difference. Can you verify for us that both routers are running the same version and same feature set of IOS?
I did notice something in the config - though I would not think that it would cause the symptoms that you describe. The working config has this configured on the async interface but the 1841 config does not:
Also I do not see a dialer list in either config. Would I assume that you removed it? Is there possibly any difference in them?
Rick
Rick
I was unable to get that far in the config. You'll notice that that is the last line in the config for that interace. I'm getting the error just before that.
Secondly, if I'm dialed in and add "async mode dedicated" I can never dial into the modem again, and a restart is necessary.
I removed the Dialer String info since it's confidential information. The numbers to be dialed are in the Dialer1 interface.
after debugging, I saw that the dialer watch is catching the down'd route , but isn't binding to anything, I pulled down a known working config to another router and found that I had the same problem with the dialer-group 1, but had the async mode dedicated in the config. This worked and was attempting to dial. Guess I can't add that line to a config while I'm on dialed into the modem
thanks for all of the help
Daniil Skopa
You don't need to add "dialer-group 1" to interface.
This command will automaticly  appears when you first time establish wireless connection with operator.
