Urgent Help - Please Help
Dear All,
I have here in my company 25 Cisco Switch 3560 .
as i know, i will configure the Switch with the Basic configuration like Hostname & IP-Address - & Gateway.
My 2 question is :-
1- if i configure the switch with the Basic Configuration like IP-Address & Subnet mask & So on , where its saved on the Switch Exactly ?
2- instead of have the 25 Switch in-front of me , and assign each switch his configuration like IP-Address & all the Things, is there any way to copy the Configurations from the switch which i configured on the Text file & then on each switch i will modify the Text file which include the configuration for that switch ( New configuration ) & then apply to that switch ( the New one ) ?
if i can do like that , can i & HOW CAN I DO IT , PLEASE HELP ME BY WRITING THE COMMAND WHICH I NEED TO FOLLOW IT ?
Thanks .
Rania.
1 REPLY
Silver
Re: Urgent Help - Please Help
Switch config is stored in NVRAM. Use the copy run start command.
Sure.
1. Configure the first switch and save the config using command above.
2. Do a show run command
3. highlight the config and copy
4. paste into notepad or other text editor
5. make your changes, highlight config and copy
6. in the new switch go into configuration mode and within hyperterminal right click and select paste to host.
7. Don't forget to save.
This should do it.
Steve
136
