Community Member
US Robotic 5686e config for remote access
I am trying to input this string from ciscos website. at&f0qle0s0=1&b0&n6&u6&m4&k0&w though everytime I input it in my hyperterminal I keep getting errors. Please advise on what I can do to fix this or if I am doing something wrong. I have changed wires, tried on other laptops at work and tried other modems and still get the same error.
Green
Re: US Robotic 5686e config for remote access
What is the error?
What are your dip switches set to?
If you just do "at" and does it come back with "OK"?
Community Member
when I type in the string and hit enter the next line says ERROR
I have dip switch settings 1, 3, 8,
When I do AT it does come back with an ok
Community Member
Thanks for the help but I found that the modme defaults to com 1 and I didnt have it set to that once I did do that I was able to type in the string. I was being pointed to my internal modem thats why I couldnt type the string.
242
