Community Member
vpdn command is not recognised
Hello All,
we have a CISCO2811-V/K9and I.O.S version is 12.3(11)T5 and we installed an ADSL VIC card.Problem is unable to enter "vpdn enable" command,Router does not recognize the command.Please give me a solution. Thanks in Advance
Kranthi Kumar -VivekaSystems(hyderabad)
1 REPLY
Re: vpdn command is not recognised
I feel your current ios doesnt support the same,you will have to find the exact ios code to load onto your router to have the support for the exact feature you require over there.
better you can lookout for software advisor tool and select the feature version you are looking out for which can solve all your requirements and also the required ios version number either 12.3 or 12.4.
Afaik later ios versions of 12.3 does support but still make sure that you are downloading the current version and the required feature set which fits onto your requirement..
http://tools.cisco.com/Support/Fusion/sfselectmdf.do
regds
147
