Webcast-Catalyst9k
vpn beginner needs one problem solution
Hello
I have two places. Place one uses cisco ASA 5505 as gateway to internet. inside lan is 192.168.0.100 and outside wan is lets say 80.80.80.80 static public adress. internal network uses 192.168.0.0 to 255 adresses for all computers. mask 255.255.255.0.
other place uses dsl modem without static public adress. lan is 10.0.0.1 as gateway and computers are 10.0.0.2 and so on.
I use only ASDM 5.2 and not terminal. can anyone tell me how to make vpn from place 2 to place 1 so I can give place 2 entry to network in place 1?
I would like to connect only from one computer in place 2 with windows vpn.
Also i need info how to set that side.
Thanx
1 REPLY
Re: vpn beginner needs one problem solution
Some forum is this,when noone can answer even basic questions!!!!!!!!!
139
