vpn clients can connect and authenticate, but thats it, help!
Ok I recently migrated my vlan's off the router on to the switch for better throughput performance,
I also have a dmvpn configured and that it working fine,
my problem is now, my vpn clients can connect but can't access any part of the network
its a ezvpn configuration everything appears to look ok, however its not
when my users connect they get a 10.0.99.x address the gateway for that is on the switch, not sure if that is they issue
They only thing the clients seem to be able to ping is the loopback of the router and the fa0/0 address
any one have any ideas as to why they can't access the network?
HELP!!!!
I have attached a sanitized copy of my router config and my switch config
Re: vpn clients can connect and authenticate, but thats it, help
make sure there is a no nat rule for traffic going to your lan users to the vpn users
I have check that and still no go, any other suggestions?
199
