VPN monitoring
garyrivers
we are using the VPN cisco solution and was wondering what recommendations you guys had on the monitoring software.
I would like to see who VPN-ed in and what their IPs are, etc.
farkascsgy
Level 4
Level 4
If you want to know these information you need check the logs in radius server if you use. I use ACS and these information are logged, or with SNMP you can collect the number of IPSec sessions. Or "show crypto session" output from this result I am sure that some script can collect the info what you need.
bye
FCS
Please rate me if I helped.
med_ddevlin
check out RadRep. It's very good and not that expensive.
thanks, I'll check it out.
Gary
