VPN PROBLEM CISCO ASA 5505
    Hello,  I have been trying to configure a VPN with Cisco Asa 5505 and Cisco VPN client 5.X for 3 weeks and I am not being able to accomplish it, so I decided to reset to factory defaults and start over again.
     I used ASDM 6.4 VPN wizard to configure it (I selected exempt local network from NAT and enabled split tunneling, but I have tried other combinations as well).
     Tunnel seems to be established properly since I do see an endpoint while using 'sh crypto isakmp sa' but 'sh crypto ipsec sa' shows no packets encrypted or decrypted, so VPN is not working as expected. I can't ping or rdp to internal LAN:
     #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
      #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
     The running-config it created is:
ciscoasa# sh run
: Saved
ASA Version 8.4(2)
hostname ciscoasa
enable password XXXX encrypted
passwd XXXX encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 172.16.1.254 255.255.0.0
interface Vlan2
nameif outside
security-level 0
pppoe client vpdn group ADSL_Telefonica
ip address pppoe setroute
ftp mode passive
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network NETWORK_OBJ_10.0.0.0_24
subnet 10.0.0.0 255.255.255.0
object network NETWORK_OBJ_172.16.0.0_16
subnet 172.16.0.0 255.255.0.0
access-list test_splitTunnelAcl standard permit 172.16.0.0 255.255.0.0
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
ip local pool test 10.0.0.1-10.0.0.254 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) source static NETWORK_OBJ_172.16.0.0_16 NETWORK_OBJ_172.16.0.0_16 destination static NETWORK_OBJ_10.0.0.0_24 NETWORK_OBJ_10.0.0.0_24 no-proxy-arp route-lookup
nat (inside,outside) dynamic interface
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 172.16.0.0 255.255.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet 172.16.0.0 255.255.0.0 inside
telnet timeout 55
ssh 172.16.0.0 255.255.0.0 inside
ssh timeout 55
console timeout 0
vpdn group ADSL_Telefonica request dialout pppoe
vpdn group ADSL_Telefonica localname adslppp@telefonicanetpa
vpdn group ADSL_Telefonica ppp authentication pap
vpdn username adslppp@telefonicanetpa password *****
dhcpd auto_config outside
dhcpd address 172.16.2.2-172.16.2.129 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy test internal
group-policy test attributes
dns-server value 172.16.1.1
vpn-tunnel-protocol ikev1
split-tunnel-policy tunnelspecified
split-tunnel-network-list value test_splitTunnelAcl
username test password XXXXXX encrypted privilege 0
username test attributes
vpn-group-policy test
username ignacio password XXXXXXX encrypted
tunnel-group test type remote-access
tunnel-group test general-attributes
address-pool test
default-group-policy test
tunnel-group test ipsec-attributes
ikev1 pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:c8935bd572dfd37e81c6aa9f9dc8207c
: end
Thank you very much for your help
Everyone's tags (5)
1 ACCEPTED SOLUTION
VIP Purple
That looks like a client-problem. Are you using an actual version of the VPN-Client? And have you tried a different PC as a client?
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
VIP Purple
Your config is not complete. You have no IP-pool assigned to your VPN and you are also missing the NAT-exemption.
You can use the VPN-wizard to add a working VPN-setup. And don't forget to enable the ASDM-option to preview commands before sending to the ASA, so that you can look at what the ASDM has configured.
Firstly I apologize for any inconvenience caused becauseI remade config just before leaving the office and I did it wrong. I have changed my original post including updated running config and some screenshots.
VIP Purple
your config looks good so far. Look at the Statistics of the VPN-client while connected and testing. Are the counters incrementing?
Re: VPN PROBLEM CISCO ASA 5505
Neither Encrypted or Decrypted packets increase, just discarded or bypassed. I have just upload some VPN Client screenshoots.
VIP Purple
Yes, it was a VPN client problem. I was doing test with a WWAN card and it seems it is not compatible with windows 7.
• The VPN Client on Windows 7 does not support WWAN devices (also called wireless data cards).
I should have read Release Notes before. Thank you very much for your help and effort.
VIP Purple
Then you could migrate to the AnyConnect-client. That's running with many data-cards. For the ASA its a different config, you need a Certificate and probably a new license (AnyConnect Essentials for about 50 to 60 bucks).
2501
