Webcast-Catalyst9k
WAN encryption in cisco 805
I need to configure WAN encrption between the two Cisco 805 routers.
Appreciate if you can help me in configuring.I am new to routers.
The items choose are as below:
Description Qty
Cisco 805 Serial Router 2
Cisco 805 Series IOS IP/FW PLUS IPSEC 3DES 2
Cisco 805 8-MB to 12-MB DRAM factory upgrade 2
Cisco 800 8MB to 12MB Flash Factory Upgrade 2
V.35 Cable, DTE Male to Smart Serial, 10 Feet 2
Prashanth
1 REPLY
Silver
Re: WAN encryption in cisco 805
The Cisco 805 Serial Router provides IPSec encryption technology to enable small offices and telecommuters to deploy VPNs. IPSec encryption provides privacy, integrity, and authenticity for transmission of sensitive information over the Internet. The unique end-to-end Cisco offering allows customers to implement IPSec encryption transparently into the network without affecting individual PCs. The Cisco 805 Serial Router with IPSec encryption allows significant cost savings by using the Internet to create secure connections between small offices and teleworkers. As a component of the Cisco VPN solution, the Cisco 805 Serial Router supports:
IPSec tunneling with 128- or 56-bit Data Encryption Standard (DES or Triple DES [3DES])
Layer 2 Tunneling Protocol (L2TP)
Generic routing encapsulation (GRE)
229
