Webcast-Catalyst9k
WAN
we r going to configure and in headquarters we r using 2801 routers and in branch locations 1841 routers so we want to connect thorugh service provider can any one suggest me the complete plan how to connect as we have to establish connection between 8-sites to headquarters.
Re: WAN
Hi Phani
You can refer the link where you have similar scenarios discussed.
do check out the Hub n Spoke concept discussed over there and also if you are planning to use NAT then use the NAT config with route map accordingly..
http://www.cisco.com/en/US/tech/tk583/tk372/tech_configuration_examples_list.html#anchor18
regds
Re: WAN
Greetings Mate,
If you want the simplest of solutions, configuring GRE between the Main branch and remote branches and configuring default route to pass all the traffic to main site.
The above scenario considers that your branches connect to Internet through your Main branch.
If your branches connect to Internet themselves, you might have to do the necessary changes in routes and perform NAT at branches.
For configuration examples, you can refer to the above post by sprem
* Please rate if helpful
128
