What is solution of nat failover with 2 ISPs?
Now I have lease line link to 2 ISPs for internet connection. I separate packets of users by accesslist such as www go to ISP1 and mail or other protocol go to ISP2 . Let's say link go to ISP1 down I need www traffics failover to ISP2 and vice versa.
Problem is acl on nat statement?
If you config about this.
access-l 101 permit tcp any any www -->www traffic to ISP1
access-l 101 permit tcp any any mail --> back up for mail packet to ISP2 down
access-l 102 permit tcp any any mail -->mail packet to ISP2
access-l 102 permit tcp any any www --> back up for www traffic go to ISP2
ip nat inside source list 101 interface s0 overload
ip nat inside source list 102 interface s1 overload
In this case is links of ISP1 and ISP2 are UP.
when you apply this acl on nat statement then nat will process each statement in order( if I incorrect please correct me) so mail traffics will match in this acl and then nat with ip of ISP1 only.
please advice solution about this
TIA
1 REPLY
Re: What is solution of nat failover with 2 ISPs?
If you have two serial links connecting to two diff service provider , then you can try this .
route-map isp1 permit 10
match ip address 101
set interface s0
route-map isp2 permit 10
match ip address 102
set interface s1
ip nat inside route-map isp1 interface s0 overload
ip nat inside source route-map isp2 interface s1 overload
ip nat inside source list 103 interface s0 overload
ip nat inside source list 104 interface s1 overload
ip route 0.0.0.0 0.0.0.0 s0
ip route 0.0.0.0 0.0.0.0 s1 100
In case if any of the link fails , automatically the other traffic would prefer the other serial.
I have not tried the config , just worked out the config on logic .pls go through and try if possible
pls see the note2 column
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080093fca.shtml#related
Hope it helps
regards
vanesh k
107
