WIC-1ADSL Won't No Shut in 1751V
Installed a new WIC-1ADSL in my 1751V yesterday. It sees the card fine, but I cannot get the IF to talk to the line. SO, I do a debug and get the following:
01:44:29: DSL: No response on write to 0x0
01:44:29: DSL(ATM0): Could not download ASW_init_3_8_131.bin
01:44:41: DSL(ATM0): No response from ASW_init_3_8_131.bin
01:44:41: DSL(ATM0): Unexpected response 0x0 to ASW_init_3_8_131.bin
I am not familiar with this error, nor could I find any indications, other than that a
failure to come up appears to point to an error in framing configuration.
Would you be kind enough to give me some potential pointers on how to best deal with this error? Is the ASW_init a file that would work if I load a new IOS in the machine, and if not, where would it be drawn from?
VIP Purple
Re: WIC-1ADSL Won't No Shut in 1751V
I think the ASW_INIT is the SDRAM initiation file that is being downloaded from an Alcatel DSLAM, which, for some reason, is not working for you. Can you post your configuration ? Also, can you try and reseat your card ? Which IOS version are you running ?
GP
Homeland#show config
Using 1630 out of 29688 bytes, uncompressed size = 2738 bytes
Uncompressed configuration from 1630 bytes to 2738 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
service compress-config
hostname Homeland
boot system flash
logging buffered 8012 errors
logging rate-limit console 100 except errors
enable secret 5
enable password 7
memory-size iomem 25
clock timezone CST -5
ip subnet-zero
no ip routing
interface ATM0
no ip address
no ip route-cache
no ip mroute-cache
no atm ilmi-keepalive
pvc 0/32
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
ip address 10.10.10.3 255.255.255.0
no ip route-cache
no ip mroute-cache
speed auto
full-duplex
interface Virtual-Template1
no ip address
interface Dialer1
ip address 255.255.252.0
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname
ppp chap password 7
ppp pap sent-username password 7
ip nat translation timeout never
ip nat translation tcp-timeout 345600
ip nat translation udp-timeout 345600
ip nat translation finrst-timeout 345600
ip nat translation dns-timeout 345600
ip nat inside source list 102 interface Dialer1 overload
ip classless
ip route profile
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
access-list 102 permit ip 10.10.10.0 0.0.0.255 any
snmp-server community public RO
snmp-server enable traps tty
call rsvp-sync
dial-peer cor custom
banner motd ^C
Welcome to HOMELAND router.
^C
line con 0
line aux 0
line vty 0 4
password 7
login
no scheduler allocate
end
Homeland#
Reseated the WIC-ADSL a couple times.
Doesn't seem to have any effect.
The carrier detect light doesn't go on at all
although the OK light on the ADSL card comes on.
I guess I'm not real sure how to find out definitively whether the problem is with the ADSL card (new/refurbed), the 1751V itself (just had the system board replaced a couple months ago) or the
IOS install itself. I'd really like any kind of
advice on how to narrow the target somehow, although
without any spare of any of the components, it
would appear to have to be something I can
determine with debugging or terminal interaction.
Thanks for any suggestions as to what I can do
here on my own.
VIP Purple
it could very well be a hardware problem. Try a different dsl operating-mode, such as ansi-dmt, or try to configure the ATM interface with the command 'dsl equipment-type cpe'. Also, try and replace the cable between your router and the splitter.
When you do a 'sh version' does the card show up at all ? Which IOS version are you running ? Can you post the 'show version' ?
GP
196
