WIC-1AM-V2 Not Working With IOS
The IOS upgrade on our 1841 routers from image
c1841-advsecurityk9-mz.124-9.T3.bin to c1841-advsecurityk9-mz.124-15.T5.bin appears to
cause problems with the WIC-1AM-V2. After the upgrade I get a line of garbage when
attaching to the modem. Is this a known issue and is there a firmware update or
configuration change that will resolve the problem?
I have tested this out on several routers that have different running configs. Also
swapped a couple modem cards out to make sure it wasn't hardware related. I then noticed
by reverting back to the old IOS they all started working again. I can only assume there
is some firmware update needed, a config change, or this might be a IOS compatibility
problem.
Hall of Fame Super Gold
Re: WIC-1AM-V2 Not Working With IOS
It can be an IOS bug. Contact the tac to have that reproduced and invetigated.
Currently have an open case. Just wondering if anyone else has experienced this?
Press on the TAC to have the problem reproduced.
At that point they will open a bug and eventually it will be fixed.
466
