XPunlimited connection through Pix 506e
I have a Pix506e that I need to open port 3389 for remote connection to a Win2003 server that is running XPunlimited for 2003 Servers. I have searched the internet and have tried numerous different access list commands to try and make this work. What I'm looking for is a CCNE that can help me get this going and maybe look at my existing configuration file to tell me what isn't set up properly.
Hall of Fame Super Blue
Re: XPunlimited connection through Pix 506e
Could you post your config together with IP addressing details
Jon
You bet....here it is
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password wVolyRqUC55O9Zpf encrypted
passwd wVolyRqUC55O9Zpf encrypted
hostname TOS
domain-name
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
access-list nat0 permit ip 172.20.10.0 255.255.255.0 172.20.11.0 255.255.255.0
access-list acl-out permit tcp any interface outside eq pcanywhere-data
access-list acl-out permit udp any interface outside eq pcanywhere-status
access-list acl-out permit tcp any host eq pcanywhere-data
access-list acl_out permit udp any host eq 5631
access-list acl_out permit tcp any host eq pcanywhere-data
access-list acl_out permit udp any host eq pcanywhere-status
access-list acl_out permit tcp any host eq 3389
access-list acl_out permit udp any host eq 3389
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 172.20.10.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool vpnpool 172.20.11.1-172.20.11.10
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list nat0
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface pcanywhere-data 172.20.10.51 pcanywhere-da
ta netmask 255.255.255.255 0 0
static (inside,outside) udp interface pcanywhere-status 172.20.10.51 pcanywhere-
status netmask 255.255.255.255 0 0
access-group acl-out in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set vpn1 esp-des esp-md5-hmac
crypto dynamic-map dynmap 1 set transform-set vpn1
crypto map seabrook 1 ipsec-isakmp dynamic dynmap
crypto map seabrook interface outside
isakmp enable outside
isakmp nat-traversal 20
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption des
isakmp policy 1 hash md5
isakmp policy 1 group 2
isakmp policy 1 lifetime 1000
vpngroup sclient address-pool vpnpool
vpngroup sclient split-tunnel nat0
vpngroup sclient idle-time 1000
vpngroup sclient password ********
telnet 172.20.10.0 255.255.255.0 inside
telnet timeout 5
ssh 24.61.165.168 255.255.255.248 outside
ssh timeout 5
console timeout 0
dhcpd auto_config outside
terminal width 80
What is the address of the server ?
You only have statics setup for PCanywhere access ie. no port 3389 ie.
static (inside,outside) tcp "public address/interface" 3389 "local server address" 3389
Jon
Jon
The server ip is 172.20.10.6
okay
So if the public address is the outside interface of the pix
static (inside,outside) tcp interface 3389 172.20.10.6 3389 netmask 255.255.255.255
if the public address is a separate public address
static (inside,outside) tcp "public ip address" 3389 172.20.10.6 3389 netmask 255.255.255.255
Jon
I will add the command and see if that aloows me to get in remotely. Another question I have is...when I make these changes to thr router and write to memory...do I need to reboot the router everytime I make changes? If so, is there a command that I can use to do the reboot remotely?
No you don't need to reboot. In fact there are very few things you need to reboot a firewall/router for.
Jon
Jon,
I added the line:
I still can't get in and I noticed that I had a line like that already in the config.
Just so you know Jon....we can't use vpn because the 3rd party database the client uses does not perform well through the tunnel
My hands are kind of tried to using remote desktop. That's why we are trying XPunlimited. I had some sucess with it before.
Thanks for looking at this for me.
158
