RV180W Do not allow VLANs to communicate
triphentech
Hello All!
I just recently switched from the WRVS4400N to the RV180W. I have 4 VLANs, and I want VLANs 1, 2, 3 to communciate freely, but I DONT want VLAN 4 to communicate with anybody, just Internet access. On the WRVS4400N, I was able to do this using the Firewall > IP Based ACL. I notcied that the RV180W, does not have such an option. I am sure there is something I am missing, I just cant find out how to isolate VLAN 4. Any ideas would be greatly appreicated.
Thank you!
5 Replies 5
David Harper
You can do this on the RV180 as well.  Checkout the screenshot below:
Cheers,
Dave.
David,
Thank you for your prompt reponse. I tried that alrady but the computers on the 2 differnet VLANs are still able to ping each other....
Any other ideas?
Can you send me a copy of your router config by PM or email at dharper@cisco.com.  Change the passwords and any other sensitive details first of course.  That config should work though so I'd like to have a look at your config and see if we are missing something.  Also, are you running the 1.0.1.9 firmware?
Cheers,
Dave.
By the way, if this is urgent, you should log a case with the SBSC (www.cisco.com/go/sbsc).  I have to head out in about an hour so it might take me a little time to look at this further.
Cheers,
Dave.
Dave,
Yes I am running 1.0.1.9.
I don't have access to the router right now, but I will email first thing tomorrow.
Thanks again!
