cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Comunicados
Bem-vindo à Comunidade de Suporte da Cisco, gostaríamos de ter seus comentários.
Cisco SG500X Channel-port has no performance
Hi!
I'm linking two Cisco switch SG500X and do not want them in stacking , then set up the two switch one chanel -group with four ports for me to ensure high throughput between two devices .
I'm transferring files from a PC connected to the first switch and another PC connected to the second switch, and all the tests all traffic flows by a single  port , despite the four ports are on Chanel -group and port -channel mode is "on" that is, without LACP and have tested by load-balance the MAC and IP , and the result was the same.
Also have a HP software , IMC " Intelligent Management Center " and in view of the topology is shown the trunk between them but should indicate the link speed 4GB and 1GB is actually indicating .
How can I configure to use these transfers all ports , getting four ( 04 ) GB ?
  • Routing & Switching
1 RESPOSTA
You need to put the chanel-group in LACP under interface for example
int g1/0/26
channel-group 1 mode active
If you look into the state of interface you will see, in your case 2000 000 Kbits (this example it 2Gbps).
sw01#show interfaces po1
Port-channel1 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 2401.c77b.1799 (bia 2401.c77b.1799)
Description: NEXUS
MTU 1500 bytes, BW 2000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is unknown
input flow-control is off, output flow-control is unsupported
Members in this channel: Gi1/0/25 Gi1/0/26
Last input 00:00:00, output 00:32:24, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 46000 bits/sec, 66 packets/sec
5 minute output rate 4000 bits/sec, 3 packets/sec
     1025608725 packets input, 377125891927 bytes, 0 no buffer
     Received 509692687 broadcasts (85461812 multicasts)
     0 runts, 26 giants, 0 throttles
     0 watchdog, 85461812 multicast, 0 pause input
     224105641 packets output, 106816187852 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
In your case should be 4000000 Kbits/sec.
Have fun,
272
Apresentações
Kudo
Respostas
