cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Comunicados
Bem-vindo à Comunidade de Suporte da Cisco, gostaríamos de ter seus comentários.
Community Member
FCS errors
Transmit GigabitEthernet1/0/24           Receive
   2991595060 Bytes                        706845689 Bytes
   3679866565 Unicast frames              3560514152 Unicast frames
     16691718 Multicast frames                174535 Multicast frames
    214310502 Broadcast frames              40653856 Broadcast frames
            0 Too old frames              1617221204 Unicast bytes
            0 Deferred frames               70029361 Multicast bytes
            0 MTU exceeded frames         2601847000 Broadcast bytes
            0 1 collision frames                   0 Alignment errors
            0 2 collision frames                   9 FCS errors
            0 3 collision frames                   0 Oversize frames
            0 4 collision frames                   0 Undersize frames
            0 5 collision frames                   0 Collision fragments
            0 6 collision frames
            0 7 collision frames           256734814 Minimum size frames
            0 8 collision frames          3824862793 65 to 127 byte frames
            0 9 collision frames          1391504807 128 to 255 byte frames
            0 10 collision frames          532607692 256 to 511 byte frames
            0 11 collision frames          218683774 512 to 1023 byte frames
            0 12 collision frames          400795216 1024 to 1518 byte frames
            0 13 collision frames                  0 Overrun frames
            0 14 collision frames          255870682 Pause frames
            0 15 collision frames
            0 Excessive collisions               367 Symbol error frames
            0 Late collisions                    343 Invalid frames, too large
            0 VLAN discard frames         1526991457 Valid frames, too large
            0 Excess defer frames                  1 Invalid frames, too small
      3802260 64 byte frames                       0 Valid frames, too small
   4036574927 127 byte frames
   1429060172 255 byte frames                      0 Too old frames
    535763836 511 byte frames                      0 Valid oversize frames
    219643482 1023 byte frames                     0 System FCS error frames
    408094765 1518 byte frames                     0 RxPortFifoFull drop frame
   1572896639 Too large frames
            0 Good (1 coll) frames
            0 Good (>1 coll) frames
Error frame check sequence: 0x00000000 incorrect, should be, o que posso fazer para resolver ?
Marcas (1)
49
Apresentações
Útil
Respostas
CriarFaça o para criar o conteúdo
